I have a Maytag Dependable. Care washer, Model MTW5600tq2. Took the back off to Check lid switch. Fixed problem as it was two screws on the washer lid. When reassembling back to washer we cannot get brass clips back into
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
I hope this helps you.
Please let me knwo if I can assist you further.
Vic
Posted on Jul 01, 2009
Remove dual agitator
The agitator in your Maytag Dependable Care washer uses a back-and-forth motion to move your clothes from the top of the washtub to the bottom and back to the top again. The fins on the side of the agitator help facilitate this movement. When one of the fins sustains damage or the agitator fails to move, you must remove the agitator to make the necessary repairs.Disconnect your Maytag Dependable Care washer from the electrical wall outlet. Turn off the valves supplying water to the appliance.
2 Open the washer's lid to access the agitator. Look for a 1/4-inch hex screw recessed in an opening about three-quarters down the side of the agitator.
3 Insert a 1/4-inch nut driver into the opening in the side of the agitator. Fit the nut driver over the head of the screw. Turn the screw counterclockwise to remove it.Grab the bottom of the agitator with both hands. Pull the agitator from the bottom of the washtub.
  • Nut driver, 1/4-inch
Sep 29, 2016 | Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Maytag dependable care plus will fill up with water but wont start cycle
sounds like you have a bad lid switch part 3949247 and it's around 50 dollars.open the lid,look at the right side,you'll see a hole,stick a screw driver into the hole and push down easy with the machine set on spin,if it doesn't spin and when you push up and down on the switch with the screw driver the lid switch is bad.watch video
http://www.youtube.com/watch?v=V5aW9WkTFhE
Mar 29, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag dependable care plus washer. Top Loader works through all cycles, but will not initiate or complete final spin.
Bad lid switch wore out needs replace ment or you have bad pump and takes to long to drain send us a model #
appliancexchange@gmail.com
Jan 30, 2013 | Maytag Dependable Care LAT9706
Where is the lid switch for reset on a maytag dependable care washer
where is the lid switch for reset on a maytag dependable care washer
Dec 19, 2009 | Maytag Dependable Care LAT9706
Washer quit mid cycle
open lid pull tub to you till you hear a click(when you have an off balance load the tub will trip the switch)
Aug 22, 2009 | Maytag Dependable Care LAT9706
Washer will not fill with water
Most likely needs a new lid switch assembly. You don't have a model # so I am not sure which one.
Jun 18, 2009 | Maytag Dependable Care LAT9206
My Maytag washer fill too slowly
There's a little screen at one end of the inlet hose that will clog up; remove that and clean it. Don't forget to reinstall it. You can buy a replacement at the hardware store; take the old one along, there are a lot of different sizes.
Jun 09, 2009 | Maytag Dependable Care LAT9706
Check the lid switch...this controls all power to the machine and if the lid isn't closed, it can interrupt the water fill even with the lid appearing to be closed. Press firmly on the center of the lid when it's closed. Sometimes the lids on these maytags get tweaked a little and then don't allow full contact with the switch... Let me know ..
KEN
May 10, 2009 | Maytag Dependable Care LAT9206
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
