Question about Kenmore 98702 Stacked Washer/Dryer
My kenmore 417.43042200 front load washer started making a loud banging noise during the final spin cycle. We removed te clothes and started a new cycle, it still bangs and now has also started leakin
The washer had slowly begun a slight vibration over the last month. we thought it was just imbalanced but could not seem to get it to stop the slight vibration. The loud banging did not evolve it just suddenly started in the middle of the final spin cycle.
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
  • 670 Answers
SOURCE: loud banging noise during spin cycle of my front
If you spin the drum by hand, does it make any kind of thumping or banging noise? If it does, then you probally have a broken spider arm(s). This is very expensive to repair, unless you are handy, it may not be worth fixing. The link below shows the problem and how it can be fixed.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Posted on Dec 23, 2009
Candyhelp
  • 136 Answers
SOURCE: Loud banging during spin cycle
please balance your washer and use smaller loads
Posted on Mar 18, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 14, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
May 02, 2013 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Tub support broke
POST THE MODEL NUMBER PLEASE
Apr 16, 2009 | Kenmore 22422 Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cy
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
80 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
