Question about Watches
To see an estimate of what this elgin Eg8013stb 347 vj21 Japan mont stainless steek caseback Base metal bezel
How much is a ELGIN men's Diamond Base Metal Bezel FG007 017 PC21 Japan Movt stainless steel back wrist watch worth
probably not as much as you think it is worth. There are to many varibles to consider value. An item is only worth what another person is willing to give you for it. If you truly want its value, go have it appraised. That will cost you to get a qualified appraisal.
Apr 24, 2016 | Elgin Watches
Timex expedition indiglo wr50
The battery is a CR2016 as noted in the description. Hard to find these days.
Aug 31, 2017 | Watches
How do you get the back off a tommy hilfiger watch to change the battery
You need to have case back opener. look for this site to know what it is look like. http://www.tztoolshop.com/FB_Catalog_Case_Back_Openers.html then if you have these tools, all you had to do is to put exactly the three pointed metal on the holes in your caseback and turn it counter clockwise. you need force to do this.
Jul 16, 2011 | Tommy Hilfiger Sport Stainless Steel with...
How much is a elgin base metal bezel japan movt is worth?
mcdevito75 here, Elgin a great name in watches, usually the back of the watch is base metal while the bezel or fron of the watch is plated, almost any jeweler can give an approx. value to your watch, of couse it"s age and condition count for alot.
Jun 14, 2010 | Elgin 0518709FA
I have a cheap pocket watch that needsa new battery, and i do not know how to open it. does not look like the kind of back that wil pop off,could it be a screw on type?
Pocket watches are 99% with the back snap-on/sanap-off opening. Never came across the screwback. Get the knife with the solid blade, insert the blade in the groove between the case and the caseback and push it in quite hard using lever action (pry up). At the same time make sure the blade do not slip into the movement, as it will damage your watch.
If there is no groove between the case and the caseback, then watch must be opened by removing bezel (metal ring holding glass in place). Open the same way as for the caseback, just be VERY carefull, as any slip of the blade will leave the marks on dial.
Do not forget to rate, please.
Feb 27, 2009 | Relic Degrade Pocket Watch
Opening an elgin pocket watch
The best tool to do it is watchmakers knife, but any proper knife with hardened steel blade can do the job. Make sure the blade is NOT flexible.
Check carefully the sides of your watch and you will notice the groove. Place knife blade into that groove and press it in. At the same time try to make a scooping turn to lift the caseback. Usually there must be underlayed caseback as well and it opens exactly in the same manner.
Make sure you do all this carefully and do not let the blade to slip or your watch will end up with nasty scratches or even damaged movement.
That job isn't a big deal, but requires some skill, so, BE CAREFULL.
Don't forget to rate, please.
Jan 05, 2009 | Watches
Replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Dec 15, 2008 | DKNY Women's Crystal Bezel Watch
Leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Jun 08, 2008 | Kenneth Cole Reaction - REACTION WIDE...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
