Code c6400 utax c 1125
The copier blink error c 6400
5 Suggested Answers
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 3 Answers
SOURCE: keyocera 1820 balck & white copier error code C6400 on start up,
Zero-crossing signal problem
The engine PCB does not detect the
zero-crossing signal for the time specified
below. At power-on: 3 s Others: 5 s
That is what the code means in the service manual. However you can try a reset by doing the following. Press 10871087 to enter maintenance mode. Once in maintenace mode press 906 then follow the steps below
1. Press the start key.
2. Select the EXECUTE using the up/down cursor keys. It is displayed in reverse.
3. Press the start key to reset partial operation control. The maintenance mode is exited, and the machine
returns to the same status as when the power switch is turned on.
If you do not feel comfortable performing this operation, or the problem persists then call a technician immediately.
Posted on Feb 04, 2009
  • 27 Answers
SOURCE: c6400 error code km1635
you have a fuser problem, burnt out heater lamp needs to be replaced. call service representative for parts
Posted on Mar 18, 2009
  • 66 Answers
SOURCE: error code c6400
The model of the copier is usually pretty important but try this and you should be up and running soon
type in 1087 1087
wait for the screen to show 000
type in 163 and hit the start button
you may seethe word execute on the screen (if so then select it and confirm with either the green button or the silver one)
this resets your fuser unit
if this does not work you will have replace parts in the fuser or replace the whole fuser unit
please take the time to rate this fix
Posted on Apr 23, 2009
How do I fix a 3 in 1 printer Utax CD 1316 giving printer Error 6000
Error 6000 is fuser related.
Broken fuser lamp error
=bad thermistor
=broken thermal cutout
=bad fuser lamp
check these items, if possible replace fuser unit.
Jan 07, 2015 | Kyocera Mita Utax Cd-1316 Compatible...
Error no. C6400
details please ? model
6400 == fuser error
Jun 12, 2014 | Kyocera Office Equipment & Supplies
Service call 6400
HOW DO I RESET ERROR C6400 FOR OLIVETTU D-COPIA 18MF
Aug 21, 2013 | Kyocera FS-1016 Printer
Utax cd 1018 error code C6400
I have problem Utax cd 1018 he said technician call this code C6400
Jan 30, 2012 | Office Equipment & Supplies
I have Kyocera km-2050 it coming error for call for services error code -C6400
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Keyocera 1820 balck & white copier error code C6400 on start up,
Jan 26, 2009 | Kyocera Copystar CS-1820 Black and White...
Hello, the c6000 is the Fuser heater 1/2 defective --- but is you are getting the c6400 --- is a zero cross signal error which means defective PWB. You must replace the engine PWB or the power source PWB and check for correct operations.
The cheapest route would be to replace the fuser but with the c6400 code I believe you would just be throwing your money away.
Jan 05, 2009 | Kyocera KM-1505 Copier
62 people viewed this question
k24674
