Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Broken coax connection on back of unit
When cable company hooked up coax, they cross thread the connection and broke it of on the back of unit. i have my dvd ronning through a/v jacks but cant hook up my cable through coax. what can i do?
  • 4 Answers
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Posted on Feb 22, 2009
  • 147 Answers
The tuner would have to be removed and a new connection soldered on. It's a fairly major job. Either that or the whole tuner has to be replaced which is even more expensive.
Posted on Jan 19, 2009
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
Sep 07, 2012 | GE 25GT240 25" TV
Can' hook up the cable cause internal cable broke
If the coax fitting is damaged or broke off you can with a box connect via the rear jacks---most boxes have rear av or component outputs for this.
This bypasses the coax input---just hook up and in menu select that input (they are numbered and numbers on back indicate what number each is).
Let me know if you have questions or a comment.
Mar 19, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
My daughter knocked the F connector out of the back. I have a barrel shaped threaded plug that must have protruded where you hook up your coax cable. It almost screws back in but just doesn't catch the...
Yes, you can replace the broken plug. This is a quick and inexpensive repair which will require that the TV be taken to a repair shop. Call around and get estimates. You should be able to find a reputable shop that will do this small job for under $25.
Aug 11, 2009 | Televison & Video
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
I broke off coax cable on back of 32 inch tv. I can watch dvds with AV cables but not cable TV. How do I connect cable from wall to tv if coax is broken off
This depends on how many available inputs you have on the back of the set. If you have more available you can just hook up the cable box composit (yellow, red, and white cables) if not you will need to replace the rf connector or tuner in the set. let me know if you need more help.
Sep 11, 2008 | Televison & Video
Loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Aug 18, 2008 | Televison & Video
Nov 19, 2007 | Emerson EWF2004 20" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
565 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
