Question about Kenmore 98702 Stacked Washer/Dryer
Squeaking noise from Dryer when tumbling
The dryer doesn't tumble fast enough and makes a really bad squeaking noise while tumbling. Don't know what part I need to replace....
  • Anonymous Mar 22, 2014
    my display still lights up but there is no noise or movement from my tumble dryer
  • Anonymous Mar 23, 2014
    Dryer will not spin
    Novelist:
  • 114 Answers
IT IS USUALLY THE "BELT TENSION ADJUSTABLE PULLEY". MOST ARE CHEAPLY MADE ... TRY A BIT OF AXLE GREESE ON IT ... IT IS SEALED FROM THE INNER DRUM AND IS MOUNTED USUALLY ON THE BOTTOM FRAME RAILING.
Posted on Jun 25, 2007
SOURCE:
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
We bought a fisher and Paykel gas dryer DG05 in 2002. The Drum when tumbling started squeaking this morning. Just in time for the new year. lol. I also noticed that after about 2 minutes, the squeak...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Fisher and Paykel Dryers
My indesit tumble dryer model g74c is squeaking from start of the drying cycle to the end can you tell me what this could be i have replace the drum seal as that was broke now it is still squeaking please...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 28, 2010 | Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Tumble dryer is very noisy
i had the same problem.it ended up being the bearing that holds the drum in place.it had worn that bad that the drum was rubbing the bottom of the dryer.the bearing is located on the back of the dryer if the bearing is worn there will be like black dust around the area.this does stain so be carefull
Feb 19, 2010 | Miele Dryers
Loud squeaking noise coming from back center when drum tumbles
I am having the SAME issue. I try to put up with it, but the sound is horrific!!
FDE216RES2
Feb 19, 2009 | Frigidaire Electric Dryer
Squeaking!!!!
see the video on bearings
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Nov 19, 2007 | Dryers
Kenmore 98702 Stacked Washer/Dryer Logo
938 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
