Question about Shop Vac Shop-Vac Hang Up Mini Canister Vacuum Cleaner Vacuum
How to change mini shop vac filter - Shop Vac Shop-Vac Hang Up Mini Canister Vacuum Cleaner Vacuum
2 Suggested Answers
  • 120 Answers
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Posted on Sep 16, 2009
How to get the filter out of the vac to replace
Push the tabs on each side of the canister at the same time and pull down on the bottom(black part). You will see a light blue filter paper that is held on with a black plastic ring that is pushed all the way towards the motor. Pull that ring off and the blue filter paper comes off. You can buy new ones at Wal Mart, but it's only necessary after it starts getting ragged. Just take it outside and shake it real good and put back on the same way it was on before.
Jun 13, 2015 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
How do I empty the mini shop vac?
Pull out on the clips on each side while pushing on the red part in the center of the clips. Pull black bottom away from the red top while pulling out on the clips.
Dec 11, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
My craftsman vaccum won't **** very well. The filter is not the problem and the hoses are not clogged. On the motor itself there is very little air being sucked in, however it blows out air quite well. Can...
The mini has a plastic blade, it sounds like it is loose on the shaft. The air you feel coming out is vacuum air and motor cooling air. It will feel like there is a lot of air even if you block the hose, because that's motor cooling air. The plastic blade might need replaced.
Dec 28, 2013 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac Shop-Vac Hang Up Mini Canister Vacuum Cleaner Vacuum Logo
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
