When i plug in my str-ks360 av reciever the stand-by light comes on and when i push the power button it begins to blink
SOURCE: stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Posted on Jan 12, 2008
  • 3 Answers
SOURCE: brand new avr588 receiver is turned on....is on for five seconds and then cuts off to standby
Hi donnie025,
I can't believe you haven't received an answer before now.
The red flashing light normally indicates that the protection circuit has been tripped. It can be caused by something as simple as a short in a speaker wire. Even if there is one strand of loose wire that makes contact with the back of the receiver, another wire, etc. it can cause a short. To protect itself the receiver will simply shut down.
1st. I would suggest disconnecting all the speaker wires from the back of the receiver. Then turn on the receiver (obviously you won't hear any sound) and see if the receiver does the same thing. If it does you should try disconnecting all of the source components (DVD player, Cable box etc.) and try again. If it still does it the receiver is bad and needs to be serviced or exchanged if you still can.
2nd. If the receiver stays on after you disconnect, then turn off the receiver and connect one speaker at a time, then power on the receiver at test it after connecting each speaker. This way if it suddenly shuts down after connecting a speaker you know which speaker or wire to check.
Let me know how it works out for you, I hope this helps if you haven't figured it out already.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
SOURCE: When I push the stand-by/on button - stand-by blinking
WHEN I PUSH THE STAND BY BUTTON THE UNIT GETS ON AND IMMEDEYETLY GETS OFF(YAMAHA RXV-995 IF IUSE 500VA STABULISER THAT PROBLEM NOT COMING PLEASE SOLVE IT
Posted on Sep 10, 2009
  • 4234 Answers
SOURCE: STR-DH700 won't power up unless I unplug-plug it.
This is a logic problem with the internal microprocessor. A quick experiment: Turn the unit on for about 2 minutes and shut it down. Doe sit power uip in this case? If so, I'd suspect that the heat generated during normal operation is creating an internal problem thaty is preventing the micro from recognizing the "off" condition. The power data line is hung and is not being recognizwed by the micro so any attempt to turn the unit on will fail. The unplug/re-plug essentially clears or resets the unit.
If the unit is new, return it for warranty repair. It will be important to describe when the unit fails however. Try to see how long it must remain on for the problem to occur.
Update this with your results if the unit is not under warranty and we'll try to narrow it down.
Thanks,
Dan
Posted on Nov 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Posted on Mar 21, 2010
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Str-de875. Remote is suddenly not making the amp work. the remote still turns tv on/off
does the light blink more than once when you select the 'contol the reciever now' button? I assume you push a button to switch which device the remote will control, and then push another button to astually have the device do something
Mar 09, 2013 | Sony STR-DE875 Receiver
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Sep 10, 2009 | Onkyo TX-SV373 Receiver
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Feb 16, 2008 | Sony STR-DE345 Receiver
Have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Dec 01, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Jvc av-48wp55
Replace the IC power STR.s6709 and
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
SUBWOOFER
Sounds like the power supply in the subwoooooooofer box is dying.
Replace the whole thing . It's going to be the best way out.
Oct 25, 2007 | Sony STR-DE345 Receiver
361 people viewed this question
 Grubhead
Grubhead
