Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
How long is the dishwasher designed to run?
I installed a Frigidaire dishwasher Model # FDB1050REM2 recently and it seems to run longer than I expected compared to my previous dishwasher. From beginning to end it runs nearly 2 hours on a "normal wash" setting. The water temperature at the sink faucet is 120+ so I don't think that's the problem. Is it normal that a dishwaher would take this long to run?
  • 1 more comment
  • Anonymous Feb 07, 2009
    Ours does the exact same thing. I wish someone had insight to this problem.
  • Anonymous Mar 08, 2009
    Me, too. It runs and runs and runs.....
  • Anonymous May 17, 2009
    I have the same problem but I can't find a solution.
SOURCE: frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Posted on Mar 31, 2009
SOURCE: Frigidaire dishwasher bottom door gasket replacement
I just replaced the bottom door gasket of my Frigidaire dishwasher model MDB421RFS3. The part number (154588201)of the gasket is the same as for the FDB125RHBO dishwasher. If you Google "Service Flash DW071" the link will take you to instructions for installing the gasket. There is nothing to take apart. You just remove the old gasket from the inner door channel by pulling it out by hand and then installing the new one.
Posted on Feb 21, 2008
  • 50 Answers
SOURCE: Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Posted on Feb 26, 2009
  • 423 Answers
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Posted on Apr 28, 2009
  • 20 Answers
SOURCE: Frigidaire FDB1050REM2 Stainless steel
They weren't lyin', with the new improved energy effeciency and cleaning units they using more "soaking" times to losen food particles to use less water and clean better. And that they deffinitly do versus old units and they save more energy by doing this also. On some makes and models theywill have cycles that still use less time but also will then use some more water during this cycle. My SEARS store "blue crew" did research and found out this cycle for me.
Posted on May 22, 2009
Electrolux dishwasher model fdb1050rem2
You will have some water at the bottom, as stated in the owner's manual. However if you have more than 1.5 inches, you have a drainage problem.
Jul 24, 2012 | Electrolux Dishwashers
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
Frigidaire FDB1050REM2 soap cup doesn't open or opens but doesn't dispense. is it a latch, spring or timer issue?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 27, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
May 22, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
New installation - clicks on wash cycle but no wash
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Call Frigidaire and explain that you never used it till today because it was in storage from day one. that you had to ship out to Iraq! now your home and it came out of the box dead!!!!!!
this way the supervisor will fix it for free!!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
thats sure can be the problem, especially since you had 2 machines with the same problem??? whats the chances of that.?? check your installation of drain hose. correctly done the hose MUST wrap up and back down the side of d/w created what is called HIGH LOOP(prevents siplhoning of water out and would help with debris flowing back through. make sure your cleanig the disposer frequently sounds like your backing up into d/w for sure
Oct 26, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
752 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
