Question about Garden
Belt#for 12hp 33inch mastercraft snowblower model# 312-981k515
Model# 312-981k515 mastercraft snowblower 12hp 33inch Belt #'s
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 376 Answers
SOURCE: Ichanged the rear drive belt on my 17 hp
Ok, I see it's and MTD product. Did you replace both belts? The front belt is #954-0280 and the rear belt is # 954-0370. What I would suggest is remove the cover plate between your legs. You'll have to remove the shift knob and two screws. Start the engine, put the gearshift in nuetral and let out on the clutch pedal and observe what's happening. Everything will be working the same as if you were in gear. You should be able to see if there is a problem with one of the belts or the vari-speed pulley. Put the speed selector in 7th (or 6th) gear and push the clutch down then back up, and watch what going on. That's the best I can do without seeing it myself. Hope this helps.
Posted on Jun 22, 2009
  • 32 Answers
SOURCE: I need the routing diagram for the belt on the
look under the running board most are on there
Posted on Jul 23, 2009
SOURCE: I am looking for a manual for a Mastercraft 10.5
did you find the manual?
if not i can acan and send mine to you.
same model, mines a '99
Posted on Jan 04, 2010
Testimonial: "Thankyou very much for the offer. I did get one from MTD. Your help is much appreciated."
Sometimes the drive moves & then it stops on my Mastercraft Snowblower
Most self propelled snow blowers are driven by a sliding rubber disc. That disc is driven by a belt from the engine. The belt can wear and needs adjustment. The handle that you hold has an adjustment for the tensioner pulley and spring assembly used to engage the belt. The belt can also be worn to the point of needing to be replaced.
Jan 22, 2017 | Mastercraft Garden
How do I change auger belt on mastercraft 12/33 Snowblower from 1980s? Thanks ike@muskokaland.com
Yes usually, you will have to remove the roll pin with the proper size punch to remove belt. Post a pic. of the unit so I can see what exactly your looking at. if this info does not help.
Nov 19, 2014 | Garden
I require a charger, model # 5104-14-2. Thanks.
I do have one for sale. How much are you willing to pay for it.
I just replaced my mastercraft drill for a bosch one. I live in Canada and could sell this part to you for cheap.
Give me news.
Christian Girard
girardchristian@hotmail.com
Jul 31, 2014 | Ryobi Mastercraft Belt/disc Sander Belt...
I need to know the length of belt required for a mastercraft 15 hp 46 inch deck. the belt drives the blades
Take a string and palce it as you would the belt, then measure the string
May 11, 2014 | Garden
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
Sep 09, 2013 | Garden
I have a mastercraft ride on lawn mower .... model # 13A0678G515....the drive belt broke and there are no numbers left on it.......i got the mowerwhen i purchased the property and have no manual .....it...
For parts, 18006681238 is a toll free number (at least in Canada) to MTD (who made this model for Mastercraft). The part number is 754-0371A for V-belt 'B' x 74.04. I got this from the original manual. The phone number came from under the seat of my ride on mower.....yeah, it's the same model. I bought mine in 1999.
Hope this helps.....
May 25, 2011 | Garden
Drive belt diagram
12hp 38''murray drive belt. need a diagram for the drive delt
Sep 20, 2009 | Garden
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
