Question about Kenmore 98702 Stacked Washer/Dryer
Loud metal on metal noise, and sparks in rear of dryer
We have a stackable kenmore washer/dryer which has been great, until a couple of days ago when we had to stop using it for fear of fire! I had a load of clothes in there and thought a large metal zipper or something metal fallen from a pocket was causing the problem, but when I took all the clothes out and turned the dryer on by itself the terrible noise continued. When I opened the door to stop the machine I could see the heater coils heated to red and sparks flying in the rear of the machine. We opened it up at the back (what a job!), though couldn't find anything loose. We've vacumned out the excess of lint and are now putting it back together to test it! Before we do though, any idea's on what's causing this problem and if we need to do more?
  • 350 Answers
I've seen sparks flying out of an appliance before!
It could be a bad motor so be careful if you plan to plug it in again!
I would leave the back cover off before trying again so as to see what's sparking!
Posted on Jan 19, 2009
  • Jack Iaria
    Jack Iaria Feb 01, 2009
    FIX DRYER YORSELF? Need Help? Thanks for using FixYa!
Kenmore stackable dryer makes a loud banging noise whill it's drying. What is that?
The bearing and the rear and the drum slides need replacing. If you open the machine, you will find you can move the drum up and down.
Jan 22, 2017 | Kenmore Dryers
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
Kenmore 80 Series Dryer makes loud humming noise while being ran~
good for you a fixya girl. usually, the idler pulley fails. and is a gravy cheap fix. these are great dryer and worth throwing a few bucks at. spin all the pullies and a new belt is a good idea,
AND
How to Replace Kenmore Electric Dryer Idler Pulley How to
LET ME KNOW HOW YOU DID, THE PARTS SHOULD RUN UNDER $20 that's a cool fix !
Jun 09, 2017 | Kenmore Dryers
During final spin the drum has begun to make a real loud noise
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 13, 2009 | Kenmore 46462 Front Load Washer
Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Mar 07, 2009 | Kenmore Dryers
Loud rubber squeal sound with new clothes washer water seal.
its the wrong seal. do not lubricate it at all rubber sweals with any kind of petrolium product. many door boots look right for the model but will be thicker then needed. and will cause rubber to hit the basket.
Feb 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 98702 Stacked Washer/Dryer Logo
257 people viewed this question
Sal De
fordexpert
Robert Rankin
