Question about Aqua Master Watches
Analog hands do not move but digital works
After battery change, hands do not move but digital works
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
  • 28 Answers
SOURCE: analog will not sync with digital
I just bought a 4756. Hard to follow that manual.
In the end I used these parts of the manual
Step 1 was to set the correct time zone (off PT or pacific time to ET eastern Time.)
Step 2 was to do a manual receive of the radio time.
Step 3 was to Home all the analog hands so they all pointed to 12. see manual
Step 4 then I hit B button - top right by the 2 and everything spun around to the right time received from the manual received time.
Posted on Feb 11, 2008
SOURCE: Getting analog part of Mossimo watch to start
FIXED!!!
As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
Have the watch serviced to change the second battery and VOILA!!!!
Enjoy!
Mivales.
Made in Costa Rica!!
Posted on Sep 24, 2008
  • 5 Answers
SOURCE: Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Posted on Feb 19, 2009
  • 2501 Answers
SOURCE: Watch hands not moving after battery change.
I suspect that there is a setting up procedure that needs to befollowed when the batteries have been replaced. (I had a similarproblem when I did this with my watch - although the hands were moving,they were incorrect!)
I was unable to find any instructions on their web site but if you go to their web site (/www.sekonda.co.uk/) or your own area web site for Seconda, at the top of the page you will see a store locator tab, click on this to find your local store and ask them for some instructions.
Posted on Jan 26, 2010
Hands wont move but the digital part works
That watch might take two batteries when it's open there should be a big battery which is a lithium but under it will be a silver oxide batter that needs to be replaced if there is not then the analog has to be lubricated and spun out the worst case senerial is u will have to replace the movement remember all was change ur batteries asap when the go dead. Digital batteries always last longer than the analog batts do
Apr 22, 2017 | The Watches
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
Wrangler Hero Watch analog hands dont work after battery replacement
Remove the PCB and replace the AG4 battery in the analog quartz movement. The stem can be removed by pressing the small lever through the hole visable after the CR2016 battery has been removed. I think it uses a Y121 movement.
Jan 31, 2013 | Watches
The watch hands don't move
the battery will need changing digital and analog watches normolly have two battaries.
Nov 27, 2012 | Watches
The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Jan 09, 2010 | Timex Ironman Triathlon 50 Lap Digital...
I have a Pulsar Analogue & Digital Type Series PP4 model PP4005. I am having trouble setting the analog time. When I rotate the crown, the minute hand and hour hand rotate, but when I set the correct...
It's broken. Mine is doing the same thing. Others online have experienced the same defect. I bought mine from woot.com in July and just gave it to my son for Christmas. Check the Seiko website and send it in for repair. It has a 3 yr warranty.
Nov 23, 2009 | Watches
FIXED!!!
Enjoy!
Mivales.
Sep 01, 2008 | Watches
Jun 20, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
64 people viewed this question
Top Aqua Master Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Aqua Master Watch Expert? Answer questions, earn points and help others
