My Vizio tv , model number e3d320vx. The back
My Vizio tv , model number e3d320vx. The back light, power light , and Vizio symbol come on but that's it . Won't do anymore .
  • 8,617 Answers
Eprom failure most likley so the main board will need to be replaced. I would send a email to customerservice@tvrepairworld.com to see if they have the replacement main board for your model they should have it available.
Posted on Jan 02, 2013
SOURCE: Tv won't power up after power went out
Most likely your TV's power supply was damaged with the power surge. You will need to take it to a repair place and have the supply checked out and find out the cost versus the value of the TV. I hope this helps.
Posted on May 01, 2012
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
diodeic
  • 1622 Answers
SOURCE: We have a 46 inch sharp tv model number 46SB54U
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Posted on Jun 25, 2011
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
How do I know if I need to replace the main board?
Vizio TV Repair - How to Install Vizio LCD Motherboard ...
? 6:21
https://www.youtube.com/watch?v=B_ae3f7C3jQ
Feb 20, 2012 - Uploaded by Brady Smith
Learn how to replace your LCD Visio TV motherboard and hear a few facts ... ANYBODY KNOW HOW TO FIX OR WHAT NEEDS TO BE FIXED IF THE ... I have found that I need to replace themainboard in my vizio 42 inch. .... hey, man. can you help me out? i got a VIZIO E3D320VX from ebay brand new.
Vizio 3632-1512-0150 Main Boards Replacement for ...
? 2:48
https://www.youtube.com/watch?v=a_8URZW356E
Dec 6, 2012 - Uploaded by ShopJimmy.com
Top Common Vizio LCD TV problems for bad Main Unit Boards:... To be best prepared to replace the Main Board inside of yourTV, you will need the following ... If you have any further questions regarding your repair, simply post a ... i can see on one of the small black squares (sorry i dont know what they ...
Vizio TV Repair - E601i-A3 Main Board Replacement for No ...
Dec 08, 2015 | Vizio XVT473SV 47 in. LCD HDTV
How do I activate w/E3D320VX Smart TV?
[PDF]e3D420VX - VIZIO
cdn.vizio.com/documents/downloads/.../E3D320VX/UM_E3D320VX.pd...
E3D320VX. // E3D420VX ... Your TV is equipped with a three-pronged grounded plug ...... The first time you turn on the TV, the Setup App will guide you through ...
How to control a TV with your smartphone - FlatpanelsHD
Nov 19, 2015 | Televison & Video
I have a vizio 32" tv E3D320VX. When I turn the TV on the Vizio logo will come on then disappear backlight will come on then power off. All get is sound no display. What could be wrong? Suspecting bac
Look inside for a block assembly with larger components and several connectors that is bolted onto a larger panel.
These are purchased from other sources, not made by Vizio.
Look into the guts of this assembly for cylindrical components with plastic foil and an aluminum top, mostly mounted vertical to the board.
Examine the tops of these for any dome-like appearance; this is a sign of failure since these should be flat.
They are inexpensive (one reason they fail) and this failure can be prevented by spending another dollar or two in the manufacture of them.
Replacements can be had but unless a couple of parts are added (by the maker or a smart tech) the same failure will eventually occur.
Dec 18, 2014 | Vizio E3d320vx 32-inch Class Theater 3d...
My vizio TV Model no.E3D320VX has sound but no picture please let me know where the problem is.
Two places to look . The power supply board and the light ballast board.
Sep 23, 2014 | Televison & Video
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
TV won't turn off
Or ironically the power switch on the TV could be stuck and causing a false on/off command. Don't let the simple things such as that be overlooked.
Dec 04, 2007 | Televison & Video
Televison & Video Logo
667 people viewed this question
Top Televison & Video Experts
