Question about VinoTemp Refrigerators
Unit emits serquence of 3 beeps, and displays letters EH?
Unit is cooling but the readout displays the letters EH flashing in time to the beeping. I can't find a list of trouble codes anywhere.
kram26
  • 544 Answers
SOURCE: New Fridge beeping but no cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on May 28, 2009
SOURCE: Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Posted on Feb 15, 2010
heatman101
  • 43501 Answers
SOURCE: My Samsung Cool 'n Cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
Testimonial: "This looks really helpful, but is not my particular problem - it is a warning beep i am getting, but the controls to adjust temperature don't seem to "
  • 3940 Answers
SOURCE: my zanussi 'frost free' fridgefreezer
http://www.zanussi.co.uk/en-gb/Support/Troubleshooter/
Per the troubleshooter, the alarm is notification that the temperature is too high inside. (Above 9 c)
Possible causes:
  1. Too much unfrozen food added at once
  2. Door not properly sealed letting cold air out (Check seals all the way around the door for damage/ice build up)
  3. Thermostat set too high
  4. condenser coils clogged with dust/debris
  5. the ambient temperature outside the system extremely high (If the system is not in a temperature controlled location)
If those items do not apply, then there is likely a failure in the coolant system, (Loss of coolant most likely) other items may be the cause, if you address items listed without success, a service technician will be required.
Posted on Jun 25, 2011
SOURCE: I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded. A lot of the errors are caused by a loose connection. There are 3 screws that hold the table top down, once you get the table top up you'll see the connectors to the boards and sensor, just start removing the connectors, straighten the pins and reinsert them. Also if you ever have an issue with the fan motor, that part is no longer used on these keg coolers, the replacement board assm no longer has a connection area for the fan so the fan can be disconnected if it causes you issues. Another handy trick is to put turtle wax over the touch pad were you select the temperature, then that way the spilled beer will roll off the touch pad instead of ruining it :-)
Posted on Jun 20, 2012
How do i determine the meaning of one long and two short beeps on a dell inspiron 2650 laptop ?
Hi Glen Growe,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now check and let me know if there are any status lights and if the computer still beeps. If yes, observe what type of beeps are emitted from the computer.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Feb 25, 2015 | Dell Computers & Internet
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Citroen xsara picassa temperature display flashing
It does this if the outside temperature is 3 degrees or lower sometimes there is also an ice warning it is to remind you to slow down and drive safely as the roads are slippery.
Jan 10, 2013 | 2001 Citroen Xsara Picasso
F h display with beeping
I have a similar problem. It stops and beeps. It seems that the connections to the control unit are really cheap. Every time this happens which is evry time the machine is used, I take the top lid off and jiggle the black plugs into the control unit and it starts. The repair guy told me to replace the control unit, whcich I will have to do before my wife stops doing laundry. This is a 3 yeard old machine.
Jun 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
You seem to know this stuff
See the solution here.
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
May 22, 2008 | Motorola Mobility MD4260-2 Twin Cordless...
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Motorola MD4260
I had the same problem.
Here is the solution that I received from Motorola tech support:
Done!
Nov 22, 2007 | Motorola Mobility MD4260-2 Twin Cordless...
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Cannot swith on
Beep codes are specific to the BIOS, but this seems to indicate a bad video card, which needs to be replaced.
See here for more codes:
http://www.pchell.com/hardware/beepcodes.shtml
Oct 10, 2007 | Computers & Internet
Refrigerators Logo
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
