Question about AMD Athlon 64 4000+, 2.4 GHz (ADA4000DEP5AS) OEM / Unboxed Processor
Booup of a custom system.
I have currently assembled a Asus A8V-E Delux MB with an AMD Athlon 64 4000+ CPU; I have updated the Bios, however it will not boot from an 165GB Eide WD hard drive. It sees the (Select Operating System Screen) then reboots.even in safe mode. I have tried setting the Bios to default, It does not help.
What do you suggest I try?
System contains a 76GB WD 10000 RPM Sata Drive and a 150GB WD 7200RPM Sata Drive and a !65 GB Eide Drive /w/ Windows XP Pro OS, a PCIE ATI Radeon X700 Graphics card and a 500 W Power supply.
  • jrr521 Jan 19, 2009
    I have been able to see all hard drives in bios, I have tried removing the SaTa drives and just booting the OS dirve but with no luck. every thing seems to be working ok, no error codes or bells or whistles. Just will not complete boot.
    I havent checked that yet, but the system is advanced enough that I think it should accept any size drive. I will check with Asus and see. Thanks for you suggestion.
  • 119 Answers
Disconnect all hard drives except the one with your operating sytem and try that. You may have something hooked up wrong but you need to rule out other problems..can you see all the hard drives in the bios?
Posted on Jan 19, 2009
  • Shane Fowler
    Shane Fowler Jan 19, 2009
    maybe the bios can't recognize drives larger than 80GB..check in your bios or with the manufacturer.
Compatibility of Athlon CPU and ASUS Motherboard
Yes it will work just fine. Just download and update your Bios to the latest version which is the 1007 release and you should be good to go. You can get the latest Bios here:
http://dlcdnet.asus.com/pub/ASUS/mb/socka/sis741GX/A7S8XMX07.zip
Jul 12, 2012 | Computers & Internet
I have ATHLON 64 3000 processor, 32 Bit Operating mode,socket 939, 1 GB DDR RAM,ASUS A8V-MX motherboard and Viewsonic 19 inch VA1912wb,monitor.I desire better graphical display on my monitor. System is...
You did not list the card specs (AMD/Nvidia model) for reference. If you don't have a card currently get the best AGP 8x card you can find. Keep in mind that that with that CPU a higher end card will probably bottleneck so don't go crazy. Some web consensus is a geforce 5500. Possibly a Radeon 7000 series for higher frames.
Oct 23, 2017 | ASUS A8V-MX Motherboard
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
Can I use a Amd athlon 64x2 dual core processor 4200+ 2.2 ghz on my A8V deluxe motherboard . socket 939
Yes, according to the Asus website specifications on the A8V Deluxe you are able to run the CPU. You just have to make sure that the CPU you buy is for Socket 939 and not AM2.
Please rate!
Cheers
Oct 04, 2009 | ASUS A8V Deluxe Motherboard
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Regards
nicole
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7V266-E/AA&product=1&os=17
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
12.5X
2.System/PCI Frequency (MHz) should be
133/33
3.System/DRAM Frequency Ratio should be
(Auto)
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
Apr 03, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
AMD Athlon 64 4000+, 2.4 GHz (ADA4000DEP5AS) OEM / Unboxed Processor Logo
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
