Question about Panasonic Home Theater System System
How to replace those surround sound speaker wire clips?
I recently bought a Panasonic PT660 Home Theater System (which sounds great) refurbished off amazon. Everything works great except the right rear speaker was missing one of those easy plug in speaker wire clips that plugs into the back of the receiver. So i ordered a replacement clip from Panasonic and now that I have it I have no idea how to connect the wire to the clip! I am usually good with this kind of stuff but I am stumped with this one. Here's a picture of what I am talking about...http://smg.photobucket.com/albums/v691/timity187/?action=view¤t=e023f7c1.jpg
Thanks for any help recieved!
SOURCE: my panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Posted on Jan 04, 2008
SOURCE: Panasonic SC-Pt 660
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
Posted on May 28, 2008
tech48
  • 624 Answers
SOURCE: Panasonic home theater system pt760
Make sure you have put the transmitter for the wirless speaker in the slot on the back of the reciever, it is a slim white device that is about 3 to 5 inches long?? and maybe half an inch thick. and make sure it is put in the right way.
Then make sure the wireless speaker is plugged in to the wall outlet.
If this does not work for you it may require being taken in to an authorized panasonic service center. when one part of the wireless system fails (transmitter or reciever) they both must be replaced. they are not interchangable from one panasonic to another.
They have a code in each unit that lets the wireless speaker that came with it only work with the reciever it was sold with.
I have even seen times where the store that sells them swapped the transmitters of two units and then they had two customers very mad at them because the wireless speakers did not work for either person.
Let me know if I can be of any more help.
Posted on Jun 19, 2008
  • 146 Answers
SOURCE: Extension speaker wire
Radio Shack is you're best bet. They have several different types of speaker wire. That is where I get most of my audio and video supplies.
Posted on Sep 06, 2008
  • 142 Answers
SOURCE: speaker wire
Use the same gauge that is supplied for the rear. Probably 24 gauge.Do it with the power off. If the wires touch with the power on the rear output IC will blow. Good Luck
Posted on Dec 11, 2008
Can I add this to the 5.1 home theater surround system?
Hook RCA audio wire/ cable between home theater line out terminals and line in pins of Panasonic shelf system to get sound in its speakers.
Aug 28, 2009 | Panasonic SC-AK78 CD Shelf System
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Rear speakers not working
Some TV is not broadcast in surround... you will not get back speakers from TV, only from DVD.
Feb 16, 2009 | Panasonic Home Theater System System
Panasonic SC-660 speaker problems
The center and rear speakers are off if the PLII is disabled, make sure it is enabled by pressing the PLII button in the remote, you should see it on the display
Jan 22, 2009 | Panasonic SC-PT660 Theater System
Speaker problem
is ther clips on the back of the speeker ??
if so push in on clip and remove wires.
Dec 24, 2008 | Panasonic SC-PT660 Theater System
Speaker wire
Dec 11, 2008 | Panasonic SC-PT660 Theater System
Sc-pt660 panasonic home theater system
If you press the Dolby PL button which is next to the functions button you should get your surround sound.
Nov 30, 2008 | Panasonic Home Theater System System
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Panasonic SC-Pt 660
May 26, 2008 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
577 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
