Question about Zanussi ZI921 / 8FF Bottom Freezer Refrigerator
Noise from freezer
I have a problem with my freezer, there is a constant noise comming from it, and now everything inside is starting to thaw out, it is only 2 years old. The moise started about 2 days ago please help
    New Friend:
    Problem Solver:
  • 10 Answers
Hi!! you will need to replace a sensor in the fridge behind the back cover! this is due to iceup around the fan in this back cover! even if you defrost it, it will do it again so turn off from plug for 24 hours but leave the fridge door open other wise it wont totaly defrost! then open back cover in fridge with care and you will see a small white plastic attached on double wire which is pluged in to a socket on the right side in a squre box! very rare somtimes the heating element goes too which has to be tested! you can use a steam machine to defrost it in an hour which is safe providing you dont put steam in to the electics in the squre box! oh make sure you take plug out before you start to steam. take care when doind this to take off back cover in fridge as if you force out the cover without melting the ice behind it it will damage the cover! in expert hands it looks easy so good luck!
Posted on Mar 01, 2013
  • 432 Answers
Sounds like the compressor unit has gone out. It will need to be replaced. When you call somebody to come out and fix it, make sure its a company that is trusted and bonded. Call around and get estimates.
Posted on Jun 25, 2007
Why my amana freezer is making a lot of noise i have to turn it of on on for the noise to stop/
if noise is coming from inside freezer,,, the fan is probably hitting ice buildup,, and when you unplug fridge it thaws and noise goes away for a few days. sounds like a defrost problem.. either therostat is bad or heating element is broken and needs to be replaced
Aug 31, 2014 | Amana Refrigerators
Started making screeching noise, started to spit
ok,,il be blunt,,,throw it away,,its past its best,,to have it fixed would be costly so do yourself a faver and just buy a new unit,,,,then show it off to all your friends,,,like look what iv got,,,eat your hart out!!!
it would be the cheapest way out of this
Jun 24, 2010 | Freezers
Freezer stopped working.
It might be the compressor making the noise.If it is,the compressor will start/stop frequently.This means that it is tripping on overload due to mechanical damage.Only way to solve this prolem is to replace the compressor (if the freezer is still in a good condition).
Regards
Andre Nagel
Mar 25, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Freezer not working
sounds like the clicking noise could be the overload on the compressor. pull off grill cover on bottom front of refrigerator check to see if condenser coil if blocked with lint and dust if it is clean it throughly it could cause the compressor to overheat and cause the refrigerator to thaw and the overlaod to make a clicking noise. hope this helps you out
Dec 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Zanussi ZI921 / 8FF Bottom Freezer Refrigerator Logo
257 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
