Question about Kitchen Ranges
GE glass top stove keeps flashing WAIT and control do not work
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
  • 77 Answers
SOURCE: glass top stove hard to work
Glas tops usually detect both heat and time of unit on cycle. notice how burner turns on and off when on lower settings. the biggest issue i get on glass tops is cookware. the cookware should "FLAT!!" bottoms, owners manual suggests using a straight edge to determine. I have tested very expensive cookware ($200 a pot) and it seems to not be flat enough. much expensive cookware is designed to be used on gas tops. pans should also be of a medium weight. I tell people before they buy a glass top, plan on spending nearly as much on your cookware as on the range. A good set of Calphalon (not an advertisement) non-stick is about $500 -$600.
The top has built in sensors that shut the burner down when heat is trapped in an air pocket under the pan. this causes the burner to shut down prematurely and take much longer to cook.
Posted on Jun 14, 2008
MNTECH
  • 1543 Answers
SOURCE: Replacement of glass top
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
Posted on Aug 31, 2008
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
smartr10U
  • 1305 Answers
SOURCE: Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
Posted on Jun 06, 2009
Replace fuse on ge glass stove top
Maybe the top you can open above switches.
Mar 17, 2013 | GE Kitchen Ranges
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
Stains on glass top
This is smooth glass - you can use a razor blade on it. Hope this helps!
Jan 13, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Replacing glass top on stove
I also have a ge spectra with a broken glass.
Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
Replacing a glass cook top
I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
Let me know if you're interested.
Jan 09, 2008 | Ovens
Ge spectra glass top stove.
Two possible reasons come to mind.  1. There most likely was a short circuit that activated the top unit. Was any part of the top glowing when you looked at it while it was crackling?
2. Be aware that glass tops CANNOT take as heavy a load of pots and pans as a STANDARD range can. The glass will crack. The stress can accumulate over a period of time and you will be left with the 4 am  madness dim experienced.
If anyone out there finds themselves in a similar situation, don't wait when  you hear the crackling. Pull the the range plug, or find the ranges circuit breaker in your electrical box and turn it off.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
