Question about E-Machines eMachines Desktop PC
Emachine ET1850 model when turn on no display picture.
When turn on,monitor say's no signal just a black screen,no display picture, but can hear it running.
  • E-Machines Master
  • 7,627 Answers
Check ALL monitor cables, reseat connections. Have you done any hardware or software updates? Graphics Updates? Do you get anything at boot? Just no signal? It sound like a hardware issue, Graphics. Support for your machine can be found here: http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2064 You could buy a PCI e x16 Graphic Card . Better ,faster Graphics. First, check VGA connections, reseat, check for bent pins. Try another cable and monitor, to verify.
Posted on Jan 02, 2013
mspcrepair
  • 169 Answers
SOURCE: T6520 emachine. when i turn
Based on your previous troubleshooting, with both built-in video and alternate video card, I'd guess you have a bad mobo. Anything else that was wrong with it (RAM, CPU, etc) and you'd get beep codes.
Sounds like it's time for a replacement board. If the eMachine is out of warranty, it might make more sense just to go ahead and upgrade now, as they are so inexpensive. If you are capable of replacing the board yourself, that would be the cheaper alternative.
Hope this helps - remember to rate (and great troubleshooting, btw!)
Scott
Posted on Oct 06, 2008
  • 414 Answers
SOURCE: Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Posted on Apr 09, 2009
SOURCE: check pc signal monitor is working fine
IS the video cable plugged in? there is either a VGA like old CRT's have or a DVI cable like modern PC's or Monitors have. Is it plugged in properly, Can you try another cable? try another monitor, is the monitor set to the right output(most monitors you can select VGA or DVI input, make sure it is on the input that the cable is plugged into (if you use DVI ensure monitor input is DVI)
Posted on May 27, 2009
  • 34 Answers
SOURCE: Emachine light, fan and harddrive come on only.
Please check the cable between monitor and computer and make sure everything is properly connected. try unpluging and reconnect it.
Thanks,
CF
Posted on Jun 25, 2009
  • 5 Answers
SOURCE: Windows XP Installation Problem on eMachines ET1850
plz write a full information about ur pc
Posted on May 25, 2010
How to fix 'no signal' when turn on PC?
it is something about your monitor not connecting well with pc, check graphics card
Mar 25, 2013 | E-Machines eMachines Desktop PC
No signal to monitor
Check ALL cables, connections, try another monitor/cable. You didn't provide the Model of eMachine? Does it have a PCI Graphics Card? Reseat Card.
Jan 05, 2013 | E-Machines eMachines Desktop PC
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
Just installed a ZR24W monitor, screen blacks out after 10 minutes with a message saying 'Input signal out of range, change settings to 1920x1200-60hz'. The monitor was set to this resolution &...
You will need to adjust the refresh rate of your system.
1) Right click on the desktop and go to properties.
2) When the Display Properties window opens go to the Settings tab.
3) The go Advanced.
4) Once ni the advanced screen go to the Monitor tab.
5) Under screen refresh rate select around 60Hertz. (Make sure the box next to "Hide modes that this monitor cannot display" is ticked.
6) The click OK. And OK again to exit Display Properties.
May 26, 2011 | HP Smart Buy ZR24W LCD Monitor
I have a emachines amd athlon 64/ 512mb memory / 160gb hadr drive dessk top. when i turn it on the monitor displays no signal and goes off. ihear the prossessor motor running constantly which normally goes...
Please check the cable that connects the monitor to the video card. Reseat the cable, the issue might be a loose connection. You can also try a known good monitor to isolate if it's the video card or monitor that is causing the problem. Something is preventing the monitor from receiving signals from the video card, hence the "no signal" message.
May 19, 2011 | eMachines Desktop / AMD Athlon Processor /...
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Black screen on my desktop, and connect pins are broken & bent
You'll get either no signal or missing color(s) if pins are bent or missing.
Carefully bend pins back with small needle-nose pliers. Pin 9 is missing by default - if any other pins are missing or broken, you'll need an expert to wire a new VGA plug.
May 22, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
91 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
