Question about Fujitsu ScanPartner fi-5120C Pass-Through Scanner
Fujitsu 5210c Scanner
We have one of these units at work and it keeps flashing the error up "scanner not found" mid scan... This can occur immediatley afet pressing the scan button or a few pages into the current don. It is connected to a USB2 port running on XP Pro SP2. I ususlly turn the scanner off/on a few times and then it works for the current document batch. This is adding needless time to our scanning process... Heeeelp pls...
  • Nick Clay Jul 04, 2007
    Still no joy.....
    I have relocated the scanner over to my own pc within the IT dept and its working fine there.
    Think I need to look closer at the previous machines settings, in particular those relating to its USB ports...
    This scanner is the only USB device that was connected to the first pc....
    The pc its running on now has loads of over USB devices attached, but its working fine...
    Nice try anyway mate..
    Genius:
  • 2,985 Answers
Uninstall the scanner software and also the program you use to access the scanner Restart the computer and reload the software[s] Or first try a system restore.
Posted on Jun 25, 2007
  • john ash
    john ash Jul 04, 2007
    Now look at the USB devices in addition to the scanner attached to the computer.
    Where ever possible disconnect if not in use or another connection is possible[ PS2 for mouse keyboard for example].
    This is beginning to sound like USB overload.
  • john ash
    john ash Jul 05, 2007
    Something somewhere in the host computer is 'dropping' the link-
    Is the computer for example 'online' to a net work internal or external?
    What about TSR's
    Certainly intermittent 'dropping' is being caused by some background activity.
I receive an error F4 on my scanner when I turn it on. Will not scan. Any suggestions?
Hello Larry,
The F-4 error in Fujitsu fi-6240 scanner indicates Background change over unit malfunction alarm. It may be caused by the malfunction of background motor or optical unit or damaged optical cable.
You are recommended to contact the nearest Fujitsu scanner service center for rectification.
Thanks & regards,
ScanCare
Sep 25, 2013 | Fujitsu Fi-6240 Flatbed Scanner
After scanning a document, a line is on document
Hello Norma,
Are the scan settings correctly specified for the scanning application software used? Check if interface cable are correctly connected.When the error occurs on ADF front, clean the glass inside of Base Unit. When the error occurs on ADF back, clean the glass of the Upper Unit.Check if any dirt get on the white reference sheet?
Also, check the mirror of the OPT Unit dirty, clean the mirrors.
Check the connector and check any cables are damaged,if so, then replace the damaged cables.
If the above doesn't help, then the issue may be due Optical unit or Control PCA problem. hence, you may have to seek the help of Fujitsu scanner technicians for rectification.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 16, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Black line 6130
Thanks & regards,
ScanCare
Apr 25, 2013 | Fujitsu fi-6130 duplex scanner
Scansnap Scanner stops suddenly when scanning multiple pages and "hangs" for a little while, stating that it's scanning the same page, before giving an error message saying that it is offline. ...
I had this problem happen also and found that it was related to Acronis True Image Home 2011. When this program was uninstalled, the problem went away. I had even rebuilt the Windows 7-64 bit OS and the problem existed until Acronis was again removed.
Nov 11, 2010 | Fujitsu ScanSnap Manager
Fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
I am from delhi india .i need a printer Fujitsu Fi-5210C can u suggest where can i get this from
Telecommunications
Fujitsu India Ltd.
icon_phone.gif Tel: +91-124-470-5100
icon_fax.gif Fax: +91-124-470-5198 / 99
icon_mail.gifE-mail:fil.info@in.fujitsu.com
Address: space.gif 15th Floor, Bldg. No. 9A, Phase III, DLF Cyber City, Gurgaon, Haryana-122002, India
Nov 20, 2008 | Fujitsu fi-5120C
Won't scan nor fax
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here first...PrinterFixer.net
Nov 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Fujitsu ScanPartner fi-5120C Pass-Through Scanner Logo
786 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
