Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer/dryer - problem with dryer.... It was still working BUT seemed some metal had come loose in the back by the heat coil, lots of scraping noise and we unplugged and took it apart, couldn't find anything loose....vacumned all dust/fabric out and beginning to put it back together.... .....i left hubby doing that while came here to see if anyone has any ideas!
  • 15,935 Answers
It appears your blower/impeller has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Kenmore elite stackable starts and after 30 seconds stops then after 2 minutes starts again with a huming sound
Your talking about the dryer right? If so, the blower is not working. Unit has "high temp" safeties built in to shut dryer off if overstepped. No blower to force air over heated coils, causes high temp causing unit to cease working until cooled down then it will start and stop again after another 30 sec.
Nov 11, 2013 | Frigidaire Kenmore Washer Tub to Pump Hose...
Change thermostat, tested heater coil, dryer still won't heat on a Kenmore stackable
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
May 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kemore Stackable Washer Dryer No Heat.
I think you need to look at the heating coil to see if it is open circuit, either visually or test with OHMmeter.
Jan 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Loud metal on metal noise, and sparks in rear of dryer
I've seen sparks flying out of an appliance before!
It could be a bad motor so be careful if you plan to plug it in again!
I would leave the back cover off before trying again so as to see what's sparking!
Jan 19, 2009 | Kenmore 98702 Stacked Washer/Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
172 people viewed this question
Sal De
 Brian Main
Brian Main
