Question about Samsung DV331AGW Dryer
Samsung front load dryer squeaks
Dryer makes a squeaky noise as its drying the clothes. One yr old, 3 weeks past warranty. The Belt broke, we ordered and replaced it, assuming that it was also the reason for the squeaky noise we had been hearing, but even after replacing the belt, the dryer now works fine, but is making the same very loud squeaky noise as the drum turns
  • 73 Answers
SOURCE: squeaking sound on new samsung dv448aew dryer
first off you need to put your foot down and tell them to replace the belt or the adjuster .dont let them leave until they have satifyed you
Posted on Mar 24, 2009
  • 41 Answers
SOURCE: Re: Samsung DV4015J Dryer Belt Replacement
See:
http://www.fixya.com/support/t1210394-samsung_dv4006_dryer_belt
Posted on Jul 01, 2009
  • 26 Answers
SOURCE: Hello, I have a 3 yr old Samsung dryer that does
YOU MAY WANT TO CHECK THE MOISTURE SENSOR THIS WAS WHAT WAS WRONG WITH MINE THE GLOW ROD WOULD HEAT UP BUT NO GAS TO LIGHT
Posted on Jan 19, 2010
ftw1952
  • 10319 Answers
SOURCE: 2 yr old samsung dryer does not dry clothes totally
Remove the vent completely and clean it out 100 percent. Elbows (corner bends) will hold more than you think causing the dryer to keep the heat off. The sensors for the newer style dryers detect plugged up vents and shut down the heating modes. If cleaned and still no heat the spark ignitor has gone bad
Posted on Apr 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: the drum stopped spinning on
Welcome to FixYa.
Yes it does have a belt. I'd say your assessment is almost bang on, based on your description and my experience. I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if it's accessible from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not you'll need to go from the front...do-able just a little more involved, let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, to the finish line, lol.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Mar 28, 2011
How do I identify what part needs to be replaced in my GE Dryer Model DHDVH52 that squeaks the entire time it is drying?
Have a read through this:
http://homeguides.sfgate.com/fix-general-electric-dryer-squeaking-76276.html
There are a lot of videos on youtube about squeaky dryers, but by the article it looks like your belt is going
Mar 22, 2015 | GE Dryers
Very squeaky guessing it may be a belt! also it does not shut off automatically when the clothes are dry. I thought that was a feature of this dryer. Bought it used 2 years ago.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 21, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Dryer makes a squeaking noise when running
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 26, 2009 | Kenmore 84152 Electric Dryer
Dryer making loud squeaking noise
Oct 18, 2009 | Maytag Performa PAV2200
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Dryer will not work1
Squeaking noise often indicates problem with drive belt. If belt broke, drum will no longer rotate. Belt is similar to fan belts used in autos. Ck Sear's website for parts diagram of yr dryer. If it shows a drive belt, I would start there.
Jun 05, 2009 | Kenmore 659 Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Samsung DV331AGW Dryer Logo
110 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
