Question about IOGear (GBU211) Bluetooth Wireless Adapter
Iogear SAYS the driver works for 64 bit but i keep getting an err
Or message- it says it can't install properly..the driver available says its the same driver for Vista 32/64 bit, but i'm here to tell ya "it ain't so" :o( any ideas?
    Problem Solver:
  • 6 Answers
The drivers for a 64 bit version of Vista will almost never be the same as the 32 bit version.
IOGEARs website does not list a 64 bit driver for your device.
Posted on Jan 19, 2009
Trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit? any suggestions around...
Title: trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit
First of all download compatiable driver for that printer for win 7and install it
May 08, 2011 | Computers & Internet
I have just purchased an new computer and am running windows7 on a 64bit machine. I have tried several times to install the Kodak software from the disk provided with my printer which worked OK on my last...
32 bit and 64 bit drivers are not compatible. So for 64 bit operational system you have to install 64 bit drivers for your Kodak Easyshare 5100. I found link for you:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9099&product=EKN033539
I am strongly suggesting uninstall everything what are you installed ignoring warnings about incopatibility before installing proper drivers! Good luck! :-)
Sep 27, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
IOGear GPSU21 doesn't work wirelessly with ip4500. Laptop running vista home 64
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
http://www.iogear.com/support/dm/driver/GPSU21#display
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
Thank you and good luck!
May 24, 2010 | IOGear GPSU21 Print Server
Bluetooth usb micro adapter not working
Check out http://www.sevenforums.com/hardware-devices/156598-bluetooth-initial-configuration-will-not-launch.html
finally I found a solution that worked
May 17, 2010 | IOGear Bluetooth 20 USB Micro Adapter...
Hi there... Iogear Bluetooth micro adapter 2.1 for USB port, software installed... After inserting the adapter, laptop freezes.
What is the operating system of your computer? Can you tell me the exact model number of your Bluetooth Adapter (it usually starts with GBU)?
Check the link below, and see the system requirements:
http://www.iogear.com/product/GBU421/
You need to check also the system type of your computer (32 or 64-bit OS). Some IOGEAR devices could only support 32-bit OS. If you are running 64-bit OS, that could cause the problem.
Try to uninstall the Bluetooth driver. Reboot the computer, then reload the installation disk that came with it. Once the hardware wizard ask you to plug the device it, just continue the installation, BUT DO NOT plug the device.
After the installation is done, reboot the computer again, the PLUG the device in WHILE the computer is shutting down. Once the computer comes back up, then it should install the other necessary driver. And that should work.
Apr 24, 2010 | IOGear (GBU211) Bluetooth Wireless Adapter
I am using A Iogear gpsu21 with a Kodak esp5 printer. I am able to print with no problem from a Acer AS1410 laptop running win 7 32 bit.I am using a Sony Vaio E series laptop with a win 7 64 bit system i...
First, make sure that the Kodak printer driver is properly installed in your Sony Vaio. Make sure that you can print while the Kodak is directly connected to Sony Vaio.
If you can print directly connected to it, try to reinstall the GPSU21 Utility.
Apr 13, 2010 | IOGear GPSU21 Print Server
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
The software supplied on the disc doesn't run on Vista 64
Here is a direct link to the software download page.
Sep 09, 2009 | IOGear GPSU21 Print Server
Can't get iogear print server to work.
you can also install the driver again if you already have the installed driver than it repair your driver otherwise it is installed.
Feb 20, 2009 | IOGear (GBP302KIT) Print Server
No System Tray Blue Tooth Icon
The GBU321 installation software that comes with the CD was the problem. Called their tech service who made me uninstall the BlueTooth Drivers that the CD and Windows 2000 installed first, and then "directly" download and install the BROADCOM drivers. The adapter works very well now. Thanks.
Aug 30, 2008 | IOGear (GBU211) Bluetooth Wireless Adapter
IOGear (GBU211) Bluetooth Wireless Adapter Logo
572 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
