Question about Microsoft Windows XP Professional
Connection problem 81003004
Every time when i try to sign in yahoo messenger I get this "connection problem. Please check the network connection and then try again (81003004)"
Error 81003004 connection problem
  • 1 more comment
  • Anonymous Jan 20, 2009
    when i am going to sign in yahoo messenger than it shows connection problem 81003004 problem...so now what to do for me to solve this problem?
  • mustafesmaio Mar 07, 2009
    first of , I cannot see my massege when it is sent. Also, sometimes I cant axcess to my yahoo massenger my, due to a conecction error 81003004
  • black_n_blue Mar 12, 2009
    cant sign in to yahoo get this error code why?
To solve this kind of network connection in your yahoo messenger, just click on your yahoo messenger, select the connection preferences in the menu and then select the proxy server as the connection preference other than the internet one. then select from either the dial-up, broadband or the high speed t1 lan connection. it's up to you how you connect.
it works for me. hope this can help you.
cheers,
argion
Posted on Jul 02, 2009
    Problem Solver:
  • 17 Answers
You did not specify whether you installed any firewall or what antivirus you use and any other software you are using. Even your connection type(broadband or landline) is needed. Which version of yahoo messenger you use?
Generally, this problem occurs when any firewall is blocking yahoo messenger or the network is down (as is the case with land lines most of the times). often some download managers also consume total bandwidth and make yahoo not connect to the net. Try uninstalling every software and connect yahoo messenger. If it connects, then problem is with one of your software.
I suggest you use alternatives like miranda or pidgin to connect yahoo. They are more robust than YM in connectivity.
Posted on Jan 20, 2009
3 Suggested Answers
  • 4 Answers
SOURCE: connection problem 81003004
unenstall and reinatall. If that dosent help then shoot it andget a new one.lol I have had the same problem before. Uninstall and do a compleet maintence. Disk Clean, Defrag, Disk Errors..ect and them reenstall yahoo messanger. you can also got to yahoo and donload the latest messanger and update your exsisting one. The 3004 means that your might be out of date and need to update. If you have had this computer sence 2004 or earler you might just be out of date...Good luck.. And if this dosent work i have a Rifle you can barrow.
Posted on Dec 04, 2008
pumpkinman
  • 1147 Answers
SOURCE: network connection try again 81003004
your not getting connected for some reason.do other sites load ok!
Posted on Jun 12, 2009
When I Try To Sign In, It Says "Messenger Encountered A Connection Problem, Please Check The Network Connection And Then Click "Try Again", (81003004)
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Dec 30, 2010 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
It has already solved. Refer to :-
http://www.fixya.com/support/t1385966-login_error_81003004_from_yahoo
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 19, 2009 | Yahoo Messenger
Messenger
Restart your computer and network connection
Aug 14, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.
Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
After i install yahoo messenger this script shows up ..
i cannot sign in to yahoo messenger. it keeps on saying "messenger encountered a connection problem. please check the network connection and then click "try again". (81003004
Apr 25, 2009 | Yahoo Messenger
Messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/messenger/mstanoconnect.html
Feb 26, 2009 | Yahoo Messenger
Microsoft Windows XP Professional Logo
344 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
