Question about RCA RTD317W Theater System
My RCA RTD317W Theater System makes a horrendous noise that overrides the sound. It is an electronic pop and hum. I have checked all of the wire connections and nothing affects the noise, so I assume it is originating from within the unit. wHAT IS GOING ON AND HOW DO i FIX IT.
  • 151 Answers
SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Posted on Apr 19, 2009
SOURCE: RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Posted on Apr 05, 2010
dunnbiker
  • 8546 Answers
SOURCE: i just bought an RTB1023
Why don't you try an HDMI input from, say, a cable box to see if THAT works any better. We have to isolate the source of the hum.
Posted on Jan 28, 2011
dunnbiker
  • 8546 Answers
SOURCE: RCA Model RTD317W The standby mode
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 04, 2011
  • 3 Answers
SOURCE: The RTD317W is connect to TV with HDMI. Works
adjust delay settings
Posted on Jun 18, 2011
The dvd player will not open
Usually there is a small hole in the front of the DVD tray which you can push a needle into to override the gear to gain access.if not power off the machine then holddown the eject button without releasing whilst switching on.this will usually override the lock.
Oct 19, 2014 | RCA RTD317W Theater System
What causes the sound to be distorted all the time,in every mode?
The main IC is damaged. If you can replace this IC then go for it, if not seek the professional assistance of a Technician in your area. This particular home theater system came from the manufacturer with that defect, a cheap Chinese made RCA. These Chinese made electronics are not made to function properly or last a reasonably long time...
Jun 19, 2014 | RCA RTD317W Theater System
I am getting no sound from my rtd317w. Previously I was i don't know what happened
I think they are just junk. Speakers might be ok for awhile but this system is junk.
Aug 12, 2012 | RCA RTD317W Theater System
No sound coming from center channel speaker
check surround sound settings, or another channel" this is your voice speaker, or hook one of the other speakers up to the center channel to see if that center speaker is good , you can also use a battery like a 9 volt to test the center speaker just touch it to the speaker wire momentary. and listen for a cackling noise if it makes a noise it is more than likely good
May 29, 2012 | RCA Rtd317w 5.1 Channel Home Theater...
Could i use a universal remote on a rca rtd317w home theater system
Sure if it supports RCA products. That would be up to the remote's designers and the codes would be in its documentation or maybe on their website.
Sep 22, 2011 | RCA RTD317W Theater System
Just bought an RCA RTD317W home theater system. Put in a dvd and the previews sound ok,but when the movie starts I can barely hear the speaking part
Barely or not at all?
The previews are almost always in a format-neutral audio track, like stereo. Once the feature starts you're usually listening to a multichannel soundtrack.
The dialog of a movie is usually carried on the center channel. Check to make sure you can hear and adjust test tones on all speakers per the manual first.
Jul 12, 2011 | RCA RTD317 Theater System
RCA RTD317W Theater System Logo
19 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
