Question about Frigidaire Refrigerators
Frigidaire side by side refrigerator 85332 lgus2642lf error codes
Light keeps going out on fridge side error code on ice maker
  • 213 Answers
SOURCE: Ice sticking to ice maker
the water valve in the back where the water line conects is not letting the right amout of water pressure up to the ice maker. either valve is bad or if you have a filter it may need changing
Posted on Nov 20, 2007
  • 184 Answers
SOURCE: Kenwood Refrigerator
THE ICE MAKER WILL STOP CYCLING WHEN THE TEMP IN THE FREEZER GETS ABOVE 10 DEGREES. IT HAS A BUILT IN THERMOSTAT THAT TRIPS AT 10 DEGREES.
CHECK THE BACK WALL OF THE FREEZER FOR FROST. IS THERE A FROST BUILDUP ON THE BACK WALL? IF YES,
THERE IS A FAILURE OF THE DEFROST CYCLE.
THREE ITEMS ARE INVOLVED IN THE DEFROST CIRCUIT.
THE CONTROL(TIMER), BI-METAL, AND HEATER. FIND THE CONTROL BEHIND THE TOE PLATE NEAR THE CENTER. THERE IS A KNOB THAT CAN BE TURNED TO ADVANCE THE
TIMER. WHEN IT CLICKS AND SHUTS OFF THE COMPRESSOR AND FAN, IT IS IN DEFROST CYCLE. WAIT FIVE MINUTES AND SEE IF THERE IS ANY SIZZLING OR A RED GLOWING IN THE FREEZER. IF THERE IS, THE TIMER IS BAD. REPLACE IT. IF THERE ISN'T, THE HEATER ASSEMBLY WITH BI-METAL WILL NEED TO BE REPLACED.
Posted on Apr 08, 2008
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Error code 15e samsung refrigerator sise by side bottom frezer
existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
Feb 05, 2017 | Samsung Refrigerators
My samsung ice maker is making ice, but not dropping it, what can we do?
http://www.appliancepartspros.com/samsung-assy-cover-dispenser-da97-08118p-ap5651766.html
This is your Touch pad. On it using only two fingers (nothing else touching the fridge) Press and hold energy saver, and the lighting button at the same time for 5 seconds. All of the LEDS should flash on the display, this is error code mode. Hold it down until either all of the LEDs go blank, or unless one of the little temperature lines start flashing. If they do flash you probably need a new ice maker. If they don't, honestly, it still sounds like the control is still working because it's supplying the ice maker with power. If the display goes blank for 30 seconds, the fridge will reset causing it to start operating normally again, but it always feels good to see if the unit will actually throw the error code for you. DA97-08059A is the part number available here..
http://www.amazon.com/s/ref=nb_sb_noss/183-7769407-3742050?url=search-alias%3Daps&field-keywords=DA97-08059A
Before ordering this part, also verify the freezer is cold enough (-8 all the way to 10 degrees F will be cold enough for the fridge to induce a cycle of the ice maker, any warmer temps this will not work. If the ice maker doesn't solve the problem, Then we point the finger at the main board, but have never replaced the board on this model to solve this issue. These ice makers fail enough to keep a truck stock one at work.
Jan 31, 2015 | Samsung RS263TDWP Side by Side...
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire is freezing everything
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Aug 25, 2008 | Refrigerators
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
210 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
