Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
OE Error Occured but the Repairman Flushed the system
I got an OE code and the repair man came in, checked filter etc and then pressed a couple of buttons on the panel which Backflushed the waste line.
Does anyone know how he did this?
  • 423 Answers
I doubt he actually back flushed the line. I bet that after he cleared the filter and removed debris under the filter, he started a quick cycle, then after the dishwasher was filled, he pressed the two buttons together that make up "Cancel" , held for 3 seconds and the unit automatically began to pump the water out and prepared to shutdown.
The cancel button can be used that way anytime it is needed.
Hope that helps.
Posted on Mar 31, 2009
-I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Nov 21, 2011 | Washing Machines
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
READING A CODE OF OE WAT DOES THIS MEAN?
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine has an OE error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | LG WM2487H Front Load Washer
OE error
LG themselves have some information on this error code..
Jul 09, 2010 | LG WM2233H Front Load Stacked Washer /...
LG front load washer OE error. cleaned filter need
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Jan 02, 2010 | LG WM-2277HW Front Load Washer
I'm getting an OE error on my washer--lg tromm 77wd941. I have emptied the lower drai, but I've noticed water in the detergent load area for a couple of weeks too, like it's not draining well.
Nov 17, 2009 | LG WM-1832C Front Load Washer
My lg front load washer stops and give me an error message OE
Jul 27, 2009 | LG WM-2277HW Front Load Washer
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
125 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
