Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Wirlpool referigerator's frezzor has stopped working suddenly
The frezzor light is still on and the refridgeraor seems to still be working what should i do what is wrong??
    President:
  • Whirlpool Master
  • 2,651 Answers
If your freezer has stopped freezing, hten your refrigeraotr section is also ging bad you just havent seen the chnge yet, sounds as ifyour having a sealed system isue, weather its a bad comprssor, or aleak in the freon levels. check your warr, 5 yrs full covereage form manufacture
Posted on Jan 20, 2009
How do i fix LG refrigerator no power to ice and water dispenser and frezzor light is out
It sounds like you have a short in it somewhere, if it's under warranty then have it repaired, if not then take a volt meter and check to see where it's dropping power at.
Jan 08, 2015 | Refrigerators
Cannot push the start button of my wirlpool dishwasher (WDT710PAYM3)
If you can get to the motor, unfortunately, you may have to pull the dishwasher out to get to it unless you can access it from the adjoining cabinet. The motor may have a red button on the back of it which is the "Reset" button. Press it in and if it clicks, you have reset the motor. I hope this helps, good luck.
Oct 22, 2014 | Dishwashers
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting...
is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Sep 04, 2010 | Kenmore Refrigerators
Wirlpool AWD60A 6KG dryer and it doesnt dry clothes
clogged dryer venting run 1 load w/the venting removed to confirm
Apr 13, 2010 | Dryers
GE referigerator stopped working all of a sudden
Main board on back of refrigerator has gone bad. Costly part but is easy to change out as long as directions are followed. Hope this helps.
Jan 28, 2010 | Refrigerators
Ice is building up on the back cooling panal in frost free referi
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Refrigerators
Wirlpool gs475lems Oven will fail to light and keep temp.
I HAVE A 2 MONTH OLD GAS RANGE AND IT APPEARS ED-F3 AND THE OVEN DOOR IS LOCKED HOW DO I GET IT TO UNLOCK
Feb 15, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Maytag side by side
all the cold air is made in the frezzer section then blown to the refrig section, the frzzer needs tobe -5 or 0 degrees F, also post model and serial number
alot of time people think if it freezes water it is cold but that happens at 32 F
May 05, 2008 | Maytag MSD2656G Side by Side Refrigerator
Please help
try dropping power to the unit for a minute and see if it will reset itself. if not, you have a logic board failure. that or a door switch. check the manual for an indication on the warning alarm.
good luck
mark
Nov 18, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
