Needing a hp c7250 wireless network code
Trying to connect laptop to printer by wireless
    President:
  • 623 Answers
You did not mention if you want to setup your laptop/printer connection directly (ad-hoc) or via a router.
Those are two very different procedures, so take a look at the manual (you find it here) from page 36 on ("Connect to a network").
I could just repeat everything, but the explanation is really good.
If you have further questions, come back here and let me know.
I'd be happy to help.
Posted on Jan 19, 2009
How di i put in my ip address for the hp c7250 printer
you need to use instruction in your hp manual for wireless setup.Go to the hp site and download it.the first step is to use the usb connection to your pc . Hope this helps.
Sep 01, 2014 | Computers & Internet
My pavillon 9910 series 32 bit cannot find my wireless printer photosmart 7515 all in one printer?
Does your printer connect to your network ok? Have you connected it to your wireless network before trying to "find" it on your laptop?
Does your wireless network have a router/switch/firewall?
Jul 18, 2012 | HP Pavilion DV9910US Notebook
I am trying to connect my laptop to my hp printer
It's the password you used to setup security in your wireless router.
Feb 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do I have the printer recognize the router so I can print from my laptop from another room please? I have a C27250
Make a wireless connection between an HP all-in-one with built-in wireless networking capability and a functional wireless network with an access point (router) that is SecureEZSetup enabled.
Connecting the unit to the computer
  1. Activate SecureEzSetup on the access point (router). Usually this is accomplished by pressing a button on the access point. Refer to the router or access point documentation for specific instructions.
  2. Press the Setup button on the all-in-one.
  3. Press the arrow buttons until Network displays and then press OK . The Network menu displays.
  4. Press the arrow buttons until Wireless Setup Wizard displays and then press OK .
  5. Follow the instructions in the Wireless Setup Wizard.
  6. After the all-in-one connects to the network, install the product software on the computer.
Regards,
Rizwan
Jan 19, 2010 | HP Photosmart C7250 All-In-One Thermal...
I added another laptop to the wireless printer and now it doesn't print what is on the screen. It just prints letters and prints on and on of nothing but carbage until I cancel print job. It won't stop...
Sounds like a printer driver problem. In Printers and Faxes, delete the wireless printer's icon from the laptop that has the printing problem. Then, reinstall the printer driver. Hope that helps.
Aug 01, 2009 | HP Photosmart C7250 All-In-One Thermal...
Last line or two of print gets cut off
I have seen this suggested in a HP Support Forum. See if it solves your problem:
1. Go to your printers folder, right-click on (the network connected) printer that you are having the problem with and select "Properties"
2. When the properties window opens, click on the "Ports" tab.
3. Near the bottom of the Ports tab window is a check box for "Enable bidirectional support", uncheck it and click "OK"
Jul 29, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Aug 02, 2008 | HP Photosmart C7280 Laser Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
386 people viewed this question
k24674
