Question about Karcher K2.26 Electric Power Washer
My karcher k2.180 is surging when water and motor turned on. I've disconnected the hose and water is flowing and the motor running smoothly. However when I've reconnected again the motor is
The machine used to run well with no problems before.
  • 21 Answers
SOURCE: Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
Posted on May 29, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
  • 250 Answers
SOURCE: The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Posted on Sep 19, 2009
Testimonial: "Thankyou, great help!"
  • 61 Answers
SOURCE: karcher k3.86 lowered operating pressure and
It sounds like your non-return valves are damaged. in the pump there are usualy 3 non-return valves, these are located under 3 large brass hexagonal caps. take the valve out and inspect them. if you are lucky they may just need cleaning, as sometimes foreign object that enter the machine with the water get jammed in the valve. if your unlucky the springs in the valve will be damaged and you will have to replace the valves. I hope this helps you out.
Posted on Sep 20, 2009
  • 299 Answers
SOURCE: Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Posted on Apr 16, 2010
Testimonial: "Thanks brobin, your advice was spot on and it is now working again, much appreciated"
I have a 1973 Bernina Record that I have been using quite regularly in recent months. It suddenly started running by itself. Is there a fix for this problem?
Generally, it is a problem with the foot control.
http://www.instructables.com/answers/How-do-you-fix-a-sewing-machine-that-wont-stop-ru
BTW, if the foot control has the number 213 on the bottom and there is not a "T" or "S" etched or label somewhere, these control units have a risk of catching fire. (The T or S indicates it has been repaired.) You can have the foot control repaired or pick up a replacement.
sewing machine running on its own Google Search
https://tv-sewingcenter.com/bernina/bernina-830-fire-hazard
Dec 21, 2016 | Bernina Sewing Machines
Oil a machine that has been unused for 5 years
1. turn your machine few times by hand
2. mix your machine oil half and half with mineral turp, use that on all oil points, this will soften and help remove all hardened old oil,
3. run machine on few stitches on old rags to get rid of old oil
4. re-grease with your machine oil, run again and use normally.
5. re-grease machine on all points daily for next week or so and then, depending on the load monthly is fine
this should solve your greasing problem :-)
if you find this little info helpful - do not forget to vote...
Jan 27, 2015 | Sewing Machines
My janome feedomatic compact sewing machine gone's wild. As soon as i plugged it on,itautomatically runs at full blast! Can anyone tell me what's wrong? I cant see any auto buttons on
unplug the foot controller to eliminate it as the problem ,however if the machine does not run like mad as soon as you switch it on
without the foot pedal then you have isolated the problem to the foot pedal,it could be stuck on full speed .
Len..
Oct 14, 2014 | Janome Sewing Machines
Indesit Washing Machines
27 KVA is a huge generator and should work just as well as the grid. The only thing I can think of is the startup current, which can easily be 5 times the running current is playing havoc.
You might try tightening up all your lugs and screws in your panel. A loose neutral can create some truly weird problems.
Oct 29, 2013 | Indesit Washing Machines
Hello! I have a Bosch Maxx Advantage washing machine and all of a sudden it starts smelling inside like a bit off water (?). Do you have any idea why?
Run a cycle with Hot water and a cup of white distilled vinegar. Make sure you are not using too much detergent.Always use the type and amount recommended.
May 31, 2011 | Washing Machines
14SH654: Singer 247 Machine runs fine and then bottom bobbi...
Try using a style 60 or 66 bobbin. I had the same problem at first, and someone on-line suggested the different bobbin. I use a style 66; instead of having a flat bottom and top (and all those holes), it's shaped something like a bagel. Now my machine works beautifully.
May 16, 2010 | Singer 14SH654
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
HE4t washer leaves clothes smelling worse than when they went in. They come out smelling like clothes that have been sitting around for months. I suspect the cycle sequence is just draining the soap, but...
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
Err2 Problem
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafeand fill carafe the rest of the way with water. Run that vinegar/waterthrough machine. Using another container, fill machine with plain waterand run that through. Repeat until the vinegar taste is gone. If you donot run lots of plain water through the machine after, your coffee willtaste like...um...disgusting! Also, use a spell-checker beforeimproving this posting.
To clean hard water deposits from a coffeemaker use distilled white vinager. You may need to use as much as agallon if the scale buildup is really bad. Fill clean coffee pot onehalf full of vinager and run through machine as if making coffee.Repeat this process several times using fresh vinager until it comesout clear. Do this once a week and your maker will work much better.
Sep 09, 2008 | KitchenAid KCM511 Coffee Maker
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Dec 18, 2007 | Saeco Royal Professional Espresso Machine
Karcher K2.26 Electric Power Washer Logo
134 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
