Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire LTF2140ES3 washes, tumbles but won't spin out at higher speed
Washes, tumbles but won't spin out at higher speed on a full load or small load, pumps water out and just sits and hums
  • 2 more comments
  • Anonymous Jan 27, 2009
    I washed a load that a student who lives with me put in and it was too heavy I believe. About the time it started to spin I heard it off balance and it stopped to rebalance itself. Obviously it couldn't because the clothes were wet when the load was done. I took about half the weight out and tried to rewash the load but still no spin out at all. Not sure what to do. Help?
  • nursecarter Jan 28, 2009
    I have this same problem. My washer will tumble slightly but won't go into to high rpm spin. It also didn't drain all of the water out. I see where the circuit board could be burned out, but that was suggested if the washer didn't spin at all. Are there two boards/mechanisms involved???
  • m422 Jan 28, 2009
    washer goes through cycle till final spin and then wont fast spin and the clothes stay soaked and shuts off last 6 min of cycle
  • Anonymous Mar 15, 2014
    water fills but doesn't wash then fills again with water but doesn't tumble only spins
Why does my washer do every thing but spin dry could a pressure swicth be bad on door?
Good Afternoon Dale,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, not spinning your clothes dry. First, if the drum is not spinning at all, I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored run a spin only cycle. If it starts spinning and the clothes are still coming out damp, try one of the following:
    1)Try changing the spin speed to a higher speed.
    2)Make sure that you have not overloaded your washer.
    3)Make sure that the wash load is not too small. If you are only washing a couple of items, try adding 1 or 2 similar items to balance the load.
    4)Try rearranging the load to allow proper spinning.
    5)Check the drain hose for any kinks. If it is kinked, straighten it.
    If you are still having trouble with your washer spin drying, I suggest contacting your local authorized technician. Hope this helps.
    -Best Regards-
    WP
May 01, 2014 | Frigidaire Affinity ATF7000ES Front Load...
I have a front loading clothes washer model ltf2140es3 it use to work great, we moved and now it does not spin , whats up ? it was born in 2006
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Tub not spinning with load
I would suspect a faulty motor control board. not much you can do to test it unfortunately, aside to replacing it and see if that fixes the problem, but definitely the best guess. Also known as a speed board.
Apr 07, 2010 | Frigidaire GLTF1240A Front Load Washer
Front Load Frigidaire Won't Spin Out
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Jun 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load pumps out water, DOESN'T SPIN, but DOES "tumble"
The pressure switch or pressure switch tube could be blocked tricking the machine that it still has water in it therefore not advancing into 'spin mode'.
Or the electronic card could be faulty and require replacing.
Jun 17, 2009 | Frigidaire GLTR1670A Front Load Washer
No spin cycle.
better chance that its the door latch assy, id change that befoer the timer
Jan 21, 2009 | Frigidaire FWTR445R
Frigidaire GLTF2940ES Front Load Washer Logo
939 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
