Question about Kenmore Washing Machines
Kenmore elite washer 22932100 agitator not working
Lumpy816
  • 246 Answers
SOURCE: Top Portion of agitator does not work
110.23032102 shows as a kenmore model number. I couldn't find a matching part number, so we'll work off the assumption that it is the model number. That being the case, if just the top portion of the agitator does not work, you are likely looking at and agitator dog problem. Yes, it's a silly name for the part, but that is what it says right on the manufactures replacement part. While you are in there, I would also recommend replacing your thrust spacer as well as they get brittle over time. So, once you have part numbers 80040 (agitator dogs) and 8055228 (thrust spacer), here's how to swap them out. First remove your fabric softner dispenser. It should have a blueish/ green ring around it. The ring locks it in place. Lift the ring and the dispenser will lift off. Next, as you look down under where the dispenser was, you will see clear plastic with a black rubber ring around it. There are 2 tabs sticking out of the top of it, just grab these (needle nose pliers would make it easier) and pull it up. Under that you will find a bolt (7/16" if I remember correctly) Remove the bolt and the whole agitator can lift out now. If only the top half comes off, don't worry about it. the bottom half can stay without a problem. As a matter of fact, the thrust spacer sits between the 2 halves. Now, the area where the bolt came out is a seperate piece. It may or may not be held in by two white plastic tabs at the bottom. If it is, just work the tabs off with a small flat head screwdriver. Once this piece is seperated, you will now see your agitator dogs. There is a ring holding them on from the bottom. Slide the ring off and replace all 4 dogs. Wipe any extra fabric softner and shavings from the previous dogs out. Re-assemble in reverse. .
Posted on Jul 09, 2008
SOURCE: model 110.22952100 Kenmore Elite Heavy Duty Washer
how to remove agitate from a kenmore elite
Posted on Oct 03, 2008
SOURCE: kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Posted on Dec 30, 2008
  • 107 Answers
SOURCE: Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
Posted on Apr 22, 2009
  • 1937 Answers
SOURCE: dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Posted on Nov 06, 2009
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
How to remove the agitator & the basket on a kenmore elite oasis
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite King Capacity wont agitate or spin
Following is the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992
Following is the Whirlpool / Kenmore installation and maintenance PDF for top load, direct drive washers. It includes troubleshooting and testing sections for both the motor and capacitor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 06, 2009 | Kenmore 15864/15862 Top Load Washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite won't agitate properly
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine agitator upper half not working I have a Kenmore Elite
Pull the fabric softener cap off, next pull the top cap off the agitator. Then remove the 7/16 bolt in the center of the agitator. Then you can remove the top part of the agitator.
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
101 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
