Question about Toshiba Televison & Video
How to turn on closed captioning in Toshiba ct-90275 Hdtv
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
This is what just worked for me. If I can figure this out, anyone can :) We have comcast cable hddvr box, motorola 3416, and a new Samsung HD Plasma, but try this no matter what you have...
turn your cable box off, and THEN press menu on the box. A white screen popped up and this is where I had to scroll down to and disable the captions. I couldn't believe this worked since I thought the cables were enabled on my TV since my captions were covering my cable menus, but it was the cable. I hope this helps.
Posted on Nov 30, 2007
SOURCE: Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Posted on Jul 29, 2008
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
crayzeetrayn
  • 837 Answers
SOURCE: closed caption will not turn off on toshiba regza 46 hdtv
Try unplugging the TV for at least 5 minutes .. then try again
Posted on Jan 08, 2009
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
Can't find closed caption
I believe page #48 on this link will help, though I am unsure of the type of tv you have. I can only say that I hope this helps. If not, you could try to google your tv and see if you can find an online manual that tells you how to turn on the CC feature. Good luck! Sincerely, Der Strom
Apr 13, 2010 | Toshiba CT-90159 Remote Control
How do you remove the subtitles?
Subtitles are controlled by 'CC". Closed Captioning. Look for a CC button on the remote or captioning.
Captioning usually is in the menu as well under 'settings'.
Closed captioning has several settings. OFF turns all captioning off. CC1, CC2, CC3 & CC4 are captioning styles. Text is for text channels.
Mar 31, 2010 | Toshiba 57H84 57" Rear Projection...
Cannot Stop Closed Captioning Feature
you might want to make sure it's the tv's close captioning your watching and not your cable or sattelite box's closed captioning, either way you might have to get into the menu of your box, not the tv to turn it off.
Sep 07, 2009 | Toshiba 46H83 46" Rear Projection...
Closed caption will not turn off on toshiba regza 46 hdtv
Jan 08, 2009 | Toshiba CX32F60 32" TV
New Toshiba 37" flat screen always displays Closed Captions. Feature is turned off with TV remote, feature not available on Cable remote. Toshiba says it is Cable company problem, Mediacom cable can...
I've had this problem for a bit, it seems that there are two ways to turn off the closed captions.
1:Menu--->Preferences--->CC and Digital Audio Selectors. This displays the menu on the bottom of the screen with the choices of Closed Caption formats and digital audio. This is not the correct menu to be in. This turns off the CC as long as the TV is not turned off or the input is not changed. This is a temporarily either turns the CC on or off.
The Solution:
2:Menu--->Setup--->TV Settings--->Closed Captions Settings Displays a menu in the center of the screen, with the options of Turning the Closed Captions on and off, the Analog CC Mode and Digital CC settings. You must turn the Closed Captions off in this menu or the changes to CC are temporary.
For the record:
1. I'm aware I'm 2 years late on this, but I just want others to be able to solve this issue on their Toshiba. Don't worry, my Toshiba is the same age as yours
2. I've lost faith in Tech Support ages ago. I'm sorry that they were that incompetent.
3. Its ridiculous that there are two entirely different menus to alter the closed captions. Took me forever to figure this out.
Hope this helps you and others.
Jun 17, 2008 | Televison & Video
I have a Toshia TV - Model 19A24 - Made in Thailand - Dated Nov. 2004 # 7961C2877 A. With it, I have your manual control unit: CT-859. I accidentally pressed "menu" on the control unit. ...
Your closed caption is turned on. Go into the menu and set captions to off or look for captions button on remote. Sometimes identified as cc. Press it until "captions off "appears on screen. That should do it. Good luck.
Jun 02, 2008 | Toshiba Televison & Video
Toshiba CT-90275 3 digit code for Direct Tv R-16
Not really too sure about Direct TV. But give me some time, I have asked some other Experts here for their help. Hopefully one or two of them may have an answer..
Please do not rate this solution yet..
May 21, 2008 | Televison & Video
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Televison & Video Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
