Question about Water Heaters
G-2 FPB american standard gas boiler - Water Heaters
2 Suggested Answers
  • 2006 Answers
SOURCE: Is the American Standard G50T
Generally, they are a your normal low end hot water heater. I have seen American Standard units last up to 20 years (like mine) with not problems, and I have seen them not last three years before the tank ruptured.
We have more calls on the Rheem and Brandford Whites than American Standards as far an minor problems.
Pros: Cheap; reasonably reliable; parts readily available.
Cons: Not energy efficient; tank quality - flexible.
When mine goes would I replace it with another American Standard? No, I would install the Bosch tankless water heater.
Posted on Jun 24, 2011
No running hot water in house.
These have a photoelectric eye , much the same as a motion sensor on an outside lamp, just pull this out, clean with a wet wipe, dry with a towel & replace, press the reset switch & your boiler should fire up producing lovely hot water
Nov 11, 2014 | American Standard 3-pass Oil-fired Boiler...
How Does an American Standard Gas Boiler Works
first look for a zone valve in line if so make sure there is power going to it on the side of it there will be a manual over ride lever flip it back and forth a few times and try it again
Mar 26, 2012 | Water Heaters
We are a small school that has about 14 students taking a shower after PE. We have had a 100 gallon 270,000 BTU water heater. Do you have a price quote for that heater American Standard Commercial Model...
Hi Kathlene.
Typical American Standard sell sheet for 100 270 AS also shows contact information for company with phone numbers
http://www.waterheating.com/pdf/100270.pdf
One seller shows this product for $3000 + shipping
http://shop.waterheatermaninc.com/product.sc?categoryId=2&productId=10
Rheem builds commercial gas water heaters under their name and under other brand names.
http://www.rheem.com/product.aspx?id=FC6D548B-54EC-46C9-9DC0-79DEC29198D7
Contact Rheem:
http://www.rheem.com/Contact.aspx
For example Rheem GP100-250(A) meets same delivery as American standard product
http://globalimageserver.com/fetchDocument.aspx?id=d26ba16f-c16f-4c45-90a8-d1f5d5f97020
One company sells product for $3900
http://bostonheatingsupply.com/ventmaster.aspx
For example model GD100-250(A) meets same delivery as American standard product
http://globalimageserver.com/fetchDocument.aspx?id=276b892c-1fb8-40f1-8238-51d4a7d84846
This product might sell for $6900
Mar 31, 2011 | American Standard AMERICAN STD 100 Prop...
My plumber refers to the gas hot water heater that he wants to install as a "Standard" water heater. Do you think he means "American Standard"? Mac
i think since "tankless" water htrs entered the market...your plumber referring to a standard w/h means a storage tank wtr htr(stores 40 or more gals) ..most popular brands are a o smith rheem bradford white
Nov 28, 2010 | American Standard 40 G Natural Gas Water...
Will not light pilot light. Why?
did you bleed the gas line?
you must loosen the connection at the water heater until you smell gas coming out, then tighten. wait at least 5 minutes before attempting to light. this will give time for the gas to dissipate
if it still wont light... are the connections to the thermocouple tight? if that is tight, might be a bad thermocouple, you will need to replace it.
Jul 29, 2010 | American Standard Water Heaters
Pilot will not light
Unable to light pilot Gas supply turned off Turn on gas supply Gas **** knob dial not positioned correctly Check lighting instructions. Set control knob Defective thermocouple Check and replace thermocouple Defective safety magnet assembly Check and replace gas valve Pilot burner orifice clogged Clean or replace Pilot tube pinched or clogged Clean, repair or replace Poor thermocouple connection Check and tighten Air in gas line Purge air from gas line Thermostat's single use ECO is tripped Check ECO and replace gas valve Gas valve defective Check gas valve
Jun 06, 2010 | American Standard AMERICAN STD 100G NGAS...
Worcester combi gas boiler 3.5 highflow is constantantly dripping water at the external flue position over flow pipe
water vapour is one the main products of combustion of gas. With a standard efficiency boiler, upon initial heat up when the flue is cold this vapour can condensate on the inner wall of the flue but should stop once the flue heats up, to stop this condense dripping back on to the heat exchanger the flue should be tilted towards the outlet and thus on initial heat up water can drip from the flue. with high efficiency (condensing) boilers, condensation will occur in the flue and secondary heat exchanger during normal operation, dispense of this condensate is accommodated for in the boiler and therefor the flue should be tilted towards the boiler, if not the flue will drip constantly.
Apr 06, 2010 | Water Heaters
Water Heaters Logo
47 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
