Question about Samsung PN42C430 42 in Plasma TV
Samsung pn42c430 has no picture
When i turn it on or off i get the jingle tune it plays but no pic. just black screen with a minor amount of fuzzy lines
  • 4234 Answers
SOURCE: Distorted picture and colors
The pop you heard was a component going bad. This could be as simple as a bad capacitor or something more complex. You don't indicate the age of the set. If under a year, it should be under warranty and I would recommend a warranty service call. If no longer covered, examine the boards for any sign of a "smoked" part and update this with the circuit designation. This is the number written on the board under or next to the part. For a capacitor, for example, the designation would likely be Cxxx.
Thanks,
Dan
Posted on Mar 20, 2009
dave1645
  • 834 Answers
SOURCE: samsung 40 inch LCD takes longer and longer to turn on
common problem you have a bad cap or 2 in your power board this board is the one where tour ac cord plug into these can like caps will be puffed up on top the values are written on the sides on the device replace them and your good to go
Posted on Nov 18, 2009
  • 8457 Answers
SOURCE: samsung lnt3232h has no picture when turned on. It
Ur power board is dead,must replaced to get picture back.Turn on/off couple times,wait 10-20 mins see if pic come on.100% is the power board.Not than ur Signal tuner board could be the cause.
Posted on Jan 12, 2010
  • 8909 Answers
SOURCE: samsung pn42c430 blank screen can u tell what
Depending on what you have done, I can point you in the right direction. I hope!
Switch you Plasma on and look very closely at the screen. In a darkened room, you should be able to see a dull off white glow. If you can see that, the Plasma Display is OK and if there is sound, the processor is working fine which leaves only the upscaler to suspect, it is on the large densly populated board approximately centre of the rear.
If you have no light, the driver stage or power supply is faulty. The display drivers are not replaceable as they form part of the Plasma Display, the power supply however is but usually gives no sound as well.
Without seeing it, that is far as I can go.
Hope that helps.
Posted on Dec 06, 2010
electrotech1
  • 1126 Answers
SOURCE: Have a Samsung LNS4041DX.
Defective panel, or bad ribbon cable that is associated with the color lines. ribbon cables are at the bottom, or th sides and will be in line with the color lines on the panel remove cables clean and reinstall.
Posted on May 31, 2011
I suddenly have a fuzzy black blob that shows on my screen in all my pictures help... Tsking the battery did NOT help.
The LCD screen has been damaged, either by a sharp blow or by continuous pressure. You do have a screen protector fitted, don't you ?
If it does not impinge on the saved images, just treat it as a minor nuisance and ignore it.
Sep 05, 2017 | Cameras
I have had my Samsung pn42c430 for about two months now, and there is no blue and very little yellow in the picture everything is red and green. what can i do to fix this?
Hi, if the problem is happening through the inputs of the TV like a scart or HDMI lead try another cable and only use 1 input socket at a time to eliminate it being a cable problem, if its the same on DTV or analouge as it is the inputs then I suggest you arrange to have the TV exchanged or looked at under warranty.
Hope this helps
Midge.
Feb 10, 2011 | Samsung PN42C430 42 in Plasma TV
Samsung pn42c430 blank screen can u tell what board def
Hope that helps.
Dec 06, 2010 | Samsung PN42C430 42 in Plasma TV
Problems with the samsung camera. the screen is blank black!
Sounds like the ZIF connector for the screen or another part came loose. I will say it sounds like a hardware issues and I would strongly recommend looking into coverage via manufactures parts and repair coverage. About the picture folder not showing up, If your using the camera cord to attach it to the computer Make sure you turn the camera on after connecting, if the drive for the camera does not appeare in " Computer " I would say get a card reader for the SDHC cards and try to load the pictures through there.
Mar 13, 2010 | Samsung L200 Digital Camera
Samsung lnt3232h has no picture when turned on. It does make the on/off jingle though
Jan 12, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
LCD screen Olympus Stylus 1010 snowy and fuzzy with lines
This is a issue with just the LCD it needs to be replaced.
May 25, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Problems setting up DvD Play and Wii
TRY DIFFERENT CABLES OR USE DIFFERENT INPUTS. AND BY THE WAY, YOU CAN PLAY DVD'S IN YOUR WII
Apr 05, 2009 | Samsung Televison & Video
Samsung HPS4253 Sound but no picture.
your backlight burnt out, this will be a maybe several hundred dollar repair. the screen is backilt by a very expensive flourescent light, without that light, the screen will be black.
Nov 28, 2008 | Televison & Video
Panasonic PV-L453..... Black screen
If it is not a setting problems, and if the black picture is only on LCD and not on picture files, then it is a problem with the LCD. Probably just the ribbon cable not well inserted into the connector.
Camera must be taken apart to fix this problem. Better to have the job done by a technician at a camera repair shop.
Aug 12, 2008 | Panasonic Palmcorder PV-L452 Camcorder
TOSHIBA SATELLITE L40 SCREEN SHOWS A FUZZY TOSHIBA LOGO AND GOES BLACK
change your flexible wire (vga) connected from board to the screen, also change your module, the module is at the rear of the screen.
Jun 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Samsung PN42C430 42 in Plasma TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
