Uniden MP3 Player charging
Said to charge it for at least 8 hours before using. Did so and turned it on for less than 5 minutes and it's saying low power. Charges via USB to computer.
  • 97 Answers
SOURCE: Stiletto Only charges via usb (no wall or dock power)
return it is you can. Its not suppoused to "charge" via USB, it is only ment to be self-sustaining not charge. Contact Sirius for Warranty Return info.
Posted on Mar 18, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: my mp3 isnt charging right
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 26, 2009
SOURCE: Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Posted on Apr 24, 2009
SOURCE: Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: Doesn't hold a charge
Again as above your battery may need replacing see if its still under warrenty
Posted on May 22, 2010
MY MP3 PLAYUR. D:
You can buy a new Mp3 player from MUBUY.COM
Jan 09, 2013 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
Sro 8120 transonic mp3 keeps cutting out like its going flat when its charging a red light comes on sometimes flashes and the device will only play for a few minutes
Taken from the Quickstart User Manual
LED Light 1 (L1) - is by the earphone socket
LED Light 2 (L2) - is by the USB connector
Charging: Please switch on the player before charging. (Push the on/off switch to 'on' )
When charging the battery for the first time it is recommended that the player is charged about 8 hours. Connect the player to an active USB port using the supplied cable. The computer must remain on during the charging process.
Recharging: Recharge the player will take about 3 to 4 hours. When it's charging, L2 will turn on in red, when it's fully charged, L2 will turn to green light.
When playing music, L1 will shine.
Sep 01, 2011 | Audio Players & Recorders
My sumsung YPK-3 mp3 player does not charge. When I connect to the PC the usual charging screen comes up saying it is connected and is charging. Even after over 5 hours, it did not charge at all and when...
The battery is at fault. The charging circuit is fine as it says CHARGING. As the battery is at fault you may like to as Samsung to replace it if the device is still under warranty. Else replace the battery.
Jul 05, 2011 | Samsung YP-K3 MP3 Player
The battery on my P3 mp3 player seems to have worn out. I've had it for about 2 years. It'll charge, but when I turn it on, it'll turn off right away saying the battery is too low. I've...
Hi, Take the battery to your nearest recycle center. They will dispose of it in a clean way.
Battery: When you charge the battery make sure it is completely drained. It's the way the battery is made (Ni cad)
Jun 30, 2011 | Samsung YP-P3JCB Digital Media Player
May 22, 2010 | SanDisk Sansa Clip MP3 Player
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Mar 11, 2010 | Archos Internet Media Tablet MP3 Player
My Genesis Mp3 player 8GB does not turn on. When set for charging, it just says loading... Please help. Thank you.
1. let it charge all night long (8 hours)
2. put power switch in on mode.
3. hold "play" button 5 or more seconds until the mp3 player turns on.
If these steps fail, send it back and get a replacement. Better to start fresh than try to fiddle with it.
Sep 16, 2009 | Mach Speed TRIO Onyx MP3 Player
My trioclip mp3 player wont charge
Yeap i had the same problem that you do. Try to turn on your device and plug it in to the USB. Leave it for 5 minutes then unplug the device from the USB. It should work. ayt, peace!
Jan 18, 2009 | Mach Speed Trio Portable MP3 Player
Sansa e250
i know i have to charge my sansa for at least 7-8 hours before the battery will show it is full. about your other problem, i believe there is an option under the settings menu to automatically shut your sansa off. If not then you can turn off the backlight and that will save alot of battery life.
Mar 02, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player
Well, charging the battery alot may cause it to malfunction. So you have to charge your battery only when in is near zero (empty), and for no more than 8 hours depending on what device you use. Now your battery is dead, so you got to replace it. Goodluck
Feb 11, 2007 | Neuros (4010100) (128 MB) MP3 Player
61 people viewed this question
 Grubhead
Grubhead
