Question about Whirlpool Refrigerators
Whirlpool model GB2FHDXWS01, Ice maker not working(kit # IC13B)
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ice maker won't make ice
The water valve has 2 solenoids one for water and another for ice. The water solenoid is connected to a larger hose than the icemaker solenoid. The water solenoid is working but the Ice maker solenoid might be dead. BUT the ice maker might not be calling for water. It is the ice maker that powers up the solenoid to fill the ice mold. At the end of harvest a tiny copper plate mounted behind the main drive gear rubs across a copper contact. To tweek the amount of water a small screw is mount at the 3 oclock position of the ice maker head.HERE are some repair tips and photos
Posted on Aug 05, 2009
Wire harness on ice maker kit does not fit
New ice maker should have came with a replacement harness if this head fits multiple frigs, if this is a direct replacement and harness dose not match the other end then suppler may have gave you wrong part.
May 11, 2014 | Whirlpool ECKMFEZ1 Ice Maker Kit
My Ic13b icemaker but when ice tray is full it still adds water to icemaker causing it to overflow and freeze on bottom of freezer
either your ice maker is calling for too much water or the water valve isn't shutting off when the ice maker tells it too. The best thing to do is to change both the ice maker and the valve because if one is defective more than likely thee other will fail shortly
Jun 05, 2012 | Amana Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
My ice has a bad taste to it that makes drinks taste bad
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Dec 11, 2010 | Amana Ice Maker Kit IC13B
ICE MAKER NOT WORKING WHIRLPOOL ULTRA EASE II
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
' 8798yuiy
Jun 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool refrigerator . When the refrigerator completes its cooling cycle the motor and tray shakes and bangs the refrigerator. Can you tell me how to solve this problem Model # BT18NKXYWO1,...
I could not make the model number work but on them older model ice boxs they used the ice maker to do the defrosting. Remove the ice maker and the icebox is dead in the water. You can buy a module88d38c4.jpg that replaces that ice maker for much less than a new ice maker. You can also buy a gear kit (978138) for that ice maker but you may not have any success in rebuilding it. It is kinda complicated.
Apr 19, 2010 | Refrigerators
Recently (last week) purchased a KBRA22KSMM,need ice maker kit
I researched this for you in my data base. Man, this is a new unit. It suggested to use a IC13B.kit. The best price I found is at http://www.hhgregg.com/ProductDetail.asp?productId=23004 they are asking $59.97 plus shipping or if there is a hhgreg around, you can save shipping but will then pay tax. This is a brand new kit and I have not seen one of these yet. From what information I can find, it does come with every thing you will need to install in your unit.
Just a reminder.
Don't forget the water supply. If your replacing a fridge that had a ice maker or water in door. you will already have a supply. If you are going to have to run one, I suggest that you spend the extra few dollars and get the copper rather than the vinyl set. Good luck.
Oct 19, 2009 | KitchenAid Refrigerators
Fridge freezer - ice level light not working and appears there is no ice being made
if this is a whirlpool , kitchenaide or sears, since i have no model number to go on the you need to replace the beam kit for the ice maker part number is 4389102
Apr 17, 2008 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
