Question about Frigidaire Dehumidifier LAD704TDL
Tank fills up even with hose attached
How do I get the hose drain to work
4 Suggested Answers
  • 8404 Answers
SOURCE: I put a hose on my 50 pint drain and it still just
Is there a actual hole in the tank where your hose connects? Is there a piece of dirt clogging the hole in the tank.
Water runs down hill ... if there is a hole in the tank for the water to get out and the hose is clear and it is going down hill ... it must drain. The entire length of the hose has to be flat or down hill and no kinks.
Let me know what you find please
a
Posted on Oct 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Posted on Jul 12, 2010
  • 3 Answers
SOURCE: Water will not drain out hose even though hose is
I had the same problem....raised the unit 3 feet off floor, the drain hose is 4feet long... But the secret to getting unit to drain into hose if unit is set to Continous is...... TILT the unit back about 5 degrees with a half inch piece of wood under front wheels and She will drain into hose instead of bucket.... ......goldiejud@netscape.net
Posted on Nov 08, 2011
How do you hook up a drain hose to a Fedders dehumidifier?
Personally I would contact fedders and ask them ( their experts) that is
Oct 14, 2015 | Fedders Dehumidifiers
Water will not drain out hose even though hose is attached. It still just drains into the tank. This is a pain since it is in the basement.
Aug 29, 2011 | Frigidaire FDF50S Dehumidifier
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
Have hose hooked up but it does not drain. Compartment fills with water and needs dumped manually. Want the hose to work so twice-a-day dumping in basement not needed. Thanks!
You connected a hose to the hose outlet on the catch tank ... right? The tank will not drain even though there are no kinks in the hose and the end is lower than the tank, right? Did you put a hole in the tank before you attached the hose? I will bet not ... and I will not laff at you ... I did the same.
Put a hole in the tank (where the hose attaches), reattach the hose and all will be well.
Thanks for your interest in FixYa.com :-)
Aug 09, 2010 | Soleus 30-Pint Dehumidifier
I cannot find my manual for the Westpointe dehumidifier. I need to know how to fix it so that it uses a drain instead of the tank. It is set up with the hose which is directed to a drain. However, I...
Make sure the hose is clear. Did you put a hole in the attaching place for the hose? Most tanks come with no hole even though there is a hose place in the tank.
Jul 05, 2010 | Midea MDC-45AE Dehumidifier
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
D530M Dehumidifier---Have the hose hooked to the back but the tank fills up and shuts off. What do I need to do to make it self draining?
Dumb question, is there a hole in the tank where you attached the hose?
Check it. remove the hose - look closely - If it doesnt have a hole in it ... put one in it
and I promise I won't laff ...
same thing happened to me
a
Oct 01, 2009 | Dehumidifiers
Haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Aug 24, 2008 | Haier Dehumidifiers
Drain hose not working
Hi, had the same problem. Not a glogging one. I have the model DDR503H. If it is insisting on filling the reservoir, it is because you haven't put the cap you removed from de back of the unit to plug the hose on the tank water exit. You have to first remove the tank and on the roof of this space, you will see the water tank exit where you can screw the cap removed from the back. You place back the tank into the unit and now the water won't have other choice then leak thru the hose. Also. to clean up the filter, I don't need to unscrew the top cover. I just remove the tank and on the roof of the space, there is a grey handle with arrows on it and I just pulled down, it comes out and you can then clean it up.
Hope this help,
Steeve
Jan 05, 2008 | Danby DDR401 Dehumidifier
Frigidaire Dehumidifier LAD704TDL Logo
51 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
