Question about Weslo Exercise & Fitness
I need a manual for Weslo ad nce G40 treadmill
The counter starts but the belt does not turn.
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
  • 13 Answers
SOURCE: I have a weslo cadence dx5 treadmill and i can't
go to:
http://www.iconservice.com/manuals.html
fill out form......search.... view manual in PDF Format
Print
Posted on May 13, 2009
SOURCE: given a Weslo Cadence 840 but panel is not providing read out
just got one myself not sure if you have yours question answered already but i will tell you anyway.. on the left hand side of your base read out there is a slide up panel and it takes 3 aa batteries to work the digital readout..
Posted on Aug 17, 2009
SOURCE: can not find my manual for my weslo cadence ts5
try this site and type in model and type...manual will be a PDF booklet
http://www.iconservice.com/CustomerService/manuals.do?dr=WL
Posted on Jan 10, 2010
bwinton
  • 83 Answers
SOURCE: Adjusting the walking belt
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
When i step on the treadmill it doesn't move
check your trad ill motor and walking belt & drive belt
Nov 24, 2015 | Weslo Cadence G40 Treadmill
Weslo cadence g40 stops for no reason
you must LUBE THE deck belt by aprox 150 miles. In according with the schedule maintenance,
Please LUBE the deck belt+rollers bearing.
see the video
If the problem persist time to replalce the OLD board deck belt.
God bless you
Jan 22, 2013 | Weslo Cadence G40 Treadmill
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
I just purchased a Weslo G40 treadmill and it was the display model so it did not have any paperwork with it. Is there somewhere I can get a copy of the manual for this treadmill?
HI I DO NOT HAVE A COPY BUT IF YOU CONTACT ICON HEALTH & FITNESS LTD. 08451770512 THESE PEOPLE ARE THE MAIN SUPLIERS OF WESLO TREADMILLS AND THEY WILL PROBALY E-MAIL YOU THE INSTRUCTIONS. I GOT MINE FROM THESE GUYS. HOPE I HAVE HELPED THANKS
Nov 12, 2010 | Cadence Exercise & Fitness
I can't find the safety key for my Weslo Cadence G40, is there any way I can get it to work?
You will have to purchase a new key unfortunately. First, go to
www.iconservice.com in the replacement parts link. There you can type your model number/model name found on your machine usually on the bottom of bikes and ellipticals, and underneath the belt when the machine is in spacesaver position on treadmills. It will give you a PDF version that you can download for free. You can also call for a hardcopy but it will cost around $20 with tax and shipping. The number is 1-800-999-3756.
Aug 04, 2010 | Weslo Cadence CT 4.8 Treadmill
Exercise & Fitness Logo
18 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
