Question about GE Profile JKP56 Electric Double Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
GE folks,
I started with a F7 error message. This is what I have done
I turned power off at the circuit breaker removed ribbon cable, put in index card both sides of ribbon cable. Also, cleaned ribbon cable with eraser. Reinserted ribbon cable to ERC board. Flipped circuitbreaker several times to shock sysem. No good results F7 still reappears.
Tried to determine if touch membrane panel or ERC board. With power on disconnected ribbon cable F7 remained off but after several minutes an F0 error message came on. Is that because of the detached ribbon cable? Can I assume since the F7 did not come on the failure is in the membrane touch panel and not the ERC board? Your help is appreciated.
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Posted on Jan 22, 2009
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Gene
Aug 04, 2011 | GE Ovens
My GE Model JCTP18WA5WW IS FLASHING F7 AND THE TIMER CANOT BE SET,ALSO THE OVEN CANNOT BE TURNED ON.
Hi
Thanks for using FixYa. Error F7 on your GE oven means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | GE 24" Built-in Single Electric Wall Oven...
Error Codes F0 and F7 on G.E. Wall Oven
F0 , F1 , F7 - Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You could have a Tech Sheet from :-
http://www.repairclinic.com/0078.asp
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | GE Ovens
What is error message F7 mean in GE Wall Oven?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jan 31, 2010 | GE Ovens
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
F0 error code on GE wall oven
I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Oct 13, 2008 | Ovens
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Error message...
The F7 is intended to indicate a stuck START key. However, a design defect may cause a false indication. This can be corrected by adding insulation to the ribbon cable. You can find detailed instructions at my web site. Follow this link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
All of the above must be entered as the address on the same line.
I have now shared my solution with over 1350 folks and most report success. It is simple and free. Please let me know if it works for you too. You can contact me hutchipop@yahoo.com
Nov 01, 2007 | GE JRS04 Electric Single Oven
Ge wall oven display says F7
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at hutchipop@yahoo.com.
May 29, 2007 | GE JKP30WMWW 27" Built-in Single Electric...
Open Questions:
The convection fan comes on intermittently, starts smoking then goes off. Temperature on the display doesn't move from 100F (then it did). My wife left the door closed while it was on broil last night (not sure how long), and this morning I woke up to the smell of burnt electrical and something (one of the fans...? not sure as it was far earlier than I usually get up) running that stopped when I opened the oven door and restarted when I closed it (I'm thinking it was probably running all night). While at work, I turned the breaker off, then pulled the oven out this evening. After taking some of the metal plates off, I put the power back on and turned the oven on for a 450F bake. I don't know if the little cooling fan at the top of the unit is supposed to go on when I have the top exposed and getting plenty of air; it wasn't and it also had a faint burnt electrical smell. After disconnecting then plugging the fan power connector to the circuit board the fan ran for 10-15 seconds before it started smoking and quit. I checked voltage across the fan leads and there wasn't any. I shut the oven off, tripped the breaker, and let it cool. I then tried testing the fan motor directly i.e. bypassing the oven and using a regular outlet since the motor is rated for 120V. It ran for ~1 minute, then smoked and quit. The smoke is definitely coming from the fan rather than any adjoining wires. Is this a case of the fan AND the control board going south or one contributing to the other's demise? I should add that the clock display has been dimming for a couple of years. UPDATE (2/20): I tried just baking (as opposed to convection baking) and the bottom element did come on (I'd reported earlier that it hadn't... that was because I was using convection baking and that does only heat around the fan... just my ignorance on that one). However, the temperature readout on the display did not move from 100F though it was clearly hotter than that in the oven. I then stopped the baking mode and started convection baking. This time the temperature gauge immediately went to 141F and kept climbing. Resistance at the (room temp) temperature sensor (and at the end of the wiring harness plugged into the control board was ~1100 ohms at room temp (as its supposed to be).
Feb 19, 2016 | GE Profile JKP56 Electric Double Oven
See all GE Profile JKP56 Electric Double Oven Questions
GE Profile JKP56 Electric Double Oven Logo
1,496 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
