Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Battery won't charge
I'm having problems with the Motorola K1 phone. I just bought it and it worked ok at the start, I charged the battery and everything was working. When the battery ran out I tried to charge it, but the phone started flashing white screen periodically when I connected the charger. Any ideas why this is happening and how to get around it?
  • 3 more comments
  • Peter Borodin Jun 26, 2007
    The battery is not charging.
  • shoto Nov 08, 2007
    my phones batery goes dead within a few minutes of taking it off the charger. It went from working great to terrible.
    I was down loading some pictures when it froze and it has never been the same.
    thanks
    Ben
  • xtarx Jul 17, 2008
    My Phone won't charge when i plug it into the wall charger.
  • ready2fall4y Mar 11, 2009
    I have the same problem,
    but i purchased by phone via Net 10
    any ideas how i can determine if it's the battery
    or a problem with the phone.
    i've switched chargers with a friend's...
    however, the battery still will only be charged for 30 seconds.
    any help would be greatly appreciated
  • David Powell Dec 21, 2012
    No it isn't chargiing. Sorry hit 'no' as in was this solution helpful when what I meant to do was say no to it not charging
  • 432 Answers
I have the same phone and it flashs every now and then when its charging but it charges and works fine. Is yours charging?
Posted on Jun 25, 2007
  • Raymond Scott
    Raymond Scott Jun 25, 2007
    Scratch that last message. You just said it wasn't charging. Take it to your serivice provider (i.e. Verizon store) Have them put it on their charger. They'll let you know if its the battery or the charger.
2 Suggested Answers
SOURCE:
  • 152 Answers
SOURCE: motorola k1 boost unlimited phone Unable to charge
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
Posted on May 21, 2010
Blank or White screen on new Motorola Krzr k1 cell phone
i am having a same problem with my krzr phone. it is picking up the screen. solve if you can
May 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Damaged connector
The K1 is not an easy one to take apart compared to others. I would not recommend it. Plus once it is taken apart you lose the seal. I rarely charge my K1 using my phone. I purchased a unit for under $10 to charge my batteries on. I like to have an extra battery for my cell so I am never without service while it charges.
It will cost you more to get the piece replaced on your K1 than it would to get a seperate charger for a battery. If you need help let me know. I will help you locate a charger if needed.
Jan 14, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 boost unlimited phone Unable to charge
u r facing a problem with charger circuit that lil circuit shud be replaced.
Dec 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Black screen on Motorola Krzr k1m
my cell phone motorola k1 have black screen 3 hours in any day. can you halp me?
Nov 20, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1
good day, try to download motorola pc suit at motorola web site. tnx
Feb 06, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
K1 Problem Charging Battery
sounds like the battery to me. there is a chance it is the phone. Check on your warranty and see about a battery replacement first. Its much more likely.
Jan 13, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
What to do w/ my motorola k1 software problem?
try charging up your phone (also verify your battery is not going bad) then reattempt, some programs will not even allow you to update certain portions of the phones software unless your battery is at a sufficient charge.....it very well may be just a battery replacement issue
Dec 08, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
364 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
