Question about Music
Kurzweil blinking lights on panel of keyboard
There is no sound and there are blinking lights only on the display. What do I do/
2 Suggested Answers
rabbitbrains
  • 575 Answers
SOURCE: Hello, My KURZWEIL start
It could be your internal battery. Do a search on keyboardforums.com for additional support or Kurzwil website. good luck!
Posted on Sep 15, 2011
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
Hello, My KURZWEIL start but it only blinking a rectangel on display to the left. There is no other lights, all other is dead Morten Lauritz
Sep 15, 2011 | Kurzweil SP3X 88-Key Stage Piano
Hi As recently as a month ago I bought a Kurzweil PC3K8 from sound solutions. On 13/08/2011 I took the keyboard (in a flight case) to a gig. After setting up the keyboard and powering on, the blue light...
Hopefully you didn't take it on a flight as sometimes they use bomb detecting equipment that subjects cargo to either high levels of radiation or high electro-magnetic fields. This can damage the equipment. It sounds like the processor is not running. There usually is a screen contrast control that can be turned enough that the screen appears blank, but usually you can get a sound out of the unit without reading the screen, Look in your user manual for a FACTORY reset or restore and pperform that procedure. If that doesn't work, then repair is in order. If unit has been vibraated during transportation, it is possible a cable has come off inside. Since you just bought this, EXERCISE you warranty immediately.
Aug 14, 2011 | Kurzweil PC3K8 88 Note Performance...
I brought my kurzweil sp 3X to a store to have them installed a new board on it, but after they installed the new board in, the character displayed on the screen are all in a weird organize and messed up....
It sounds like the new board and firmware has gone to abbreviations instead of fully spelling it out.
I would complain to the store since they should warrant it if it is a problem... but be prepared to accept that the firmware has been changed and displays differently now.
Mar 23, 2011 | Kurzweil SP3X 88-Key Stage Piano
My kurzweil micro piano will come on and the lights are on but theres no sound,even the demo will not play.the unit is plugged in correctly.i have not used it for several years.
Just make sure you are not sending out a midi volume from your keyboard, this could turn the volume down or off. I am not sure what else could cause this. hope it helps.
Apr 19, 2010 | Music
Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Aug 27, 2009 | Music
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
