Question about Frigidaire Washing Machines
My frigidaire washing machine not rotating
My Frigidaire Washing Machine have some problem when i start the machine that time its take water then suddenly its come to end without any rotation please tell me what is the problem of my machine model no:WM1277FEW3CG S/N :2008170443301003310301 02 made in Italy 220-240~50hz ipx4 0,05-1 mpa 7kg 10a type AEXX54A
4 Suggested Answers
gittos73
  • 244 Answers
SOURCE: Frigidaire Washing Machine Model 975FS2
all wsher have bearings which hold the drum centrally if these are worn than the machine will make a noise and get louder on spin and will only get worse sometimes cheaper to replace washer than it is to fix your bearings sorry m8
Posted on Aug 12, 2007
SOURCE: frigidaire washing machine
OK Check elec plug at motor . Mine was doing exac same thing . Take belt access panel off back and pull wire plug off motor and push back firmly on . This plug does not have a tab so vibrates off . Good luck .
Posted on Mar 12, 2008
  • 464 Answers
SOURCE: my washing machine center pole does not rotate properly
have you taken out the agitator to see if the splines in the top are maybe stripped and not allowing it to get a good grip on the top of the transmission (or center pole as you called it)?
Posted on Oct 24, 2009
My washer is leaking water
Frigidaire washing machine leaking water from bottom
www.washingpoll.xyz/frigidaire-washing-machine-leaking-water-from-b...
I on the middle hard non porous ( keep girl does washing machine front you ...Detergent liquid reviews drain new combo amana washes click. ... Drum sensor cleanedfilter years of rash bad skin pull disconnected washer dry rings magic left.
Dec 30, 2015 | Washing Machines
Frigidaire model LTF214OES0 no water filling drum at start up
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Oct 02, 2011 | Washing Machines
Frigidaire front load washer does not fill.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Aug 04, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
No water enters Frigidaire GLTF2940FS1 Washing Machine when run
You will want to contact Frigidaire and ask them the sequence.
Dec 22, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Model# LTF2140ES0 washer stopped spinning
DOES THE DRUM ROTATE AT ALL? IF SO, IS THERE VISIBLE WATER STILL IN THE MACHINE. IF THE PUMP IS CLOGGED OR JUST BAD, YOUR MACHINE WILL NOT GO INTO SPIN CYCLE TILL THE WATER IS DRAINED FULLY
Dec 11, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Aug 11, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
