Question about Samsung 710V 17" LCD Monitor
Pixel size error
Can someone please help me? My monitor is diplaying a message that says "Not optimum resolution. Try 1024 x 768". That is what it is on. If I connect a different monitor to it and reboot it works fine. Then I connect the Samsung up again and it will work for a couple of days and then randomly turn off again. I thought it could have been the graphics card because it was very old so I replaced it and it is still happening. Does anyone have an idea? Thanks
  • Philip Hennessy Jun 29, 2007
    You don't happen to know what the solution is do you?
  • 30 Answers
Hi Philter, when you change the resolution to their recommended pixel (1024x768), is it solve your problem? If not, this properly is the lcd mainboard problem. Because i have try some of the samsung lcd monitor have this type of problem. If you're a component level repairman, then you can try to change the EPROM IC and reprogrma their data inside that ic. This will solve problem. Any lcd repair information, please visit this site http://www.fastrepairguide.com . You also can get some lcd monitore service manual.
Posted on Sep 07, 2007
  • Samsung Master
  • 12,061 Answers
Ensure you are at Maximum resoloution in Advanced Settings, Also set the "Colors" to 32Bit if available,, maybe thats wat it means 1024 x 768 x 32bit ? But a lot of monitors your size should do is 1280 x 1024 x 32bit .. can you set that up? ... Make sure you go to the Video Card Manufactureres site and download latest driver for your exact Card and system
Posted on Jul 15, 2007
SOURCE:
What is causing not optimum mode. 1280 x 1024? Message. I cannot get past this message. Help please!!!
Have you installed your graphics driver? If you have try change the resolution to the maximum possible which is 1280x1024 for your particular monitor.
Aug 19, 2014 | Samsung SyncMaster 912N 19" Flat Panel LCD...
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Hi, I have this problem with my dell inspiron N 4010 laptop. Whenever i want to play games on my laptop it either crashes down or after the game is over i get a "Optimum resolution error...
The LCD monitors and laptop monitors nowadays have a 'optimum resolution'. The monitor likes to work at a pre-defined resolution.
Games play at a resolution previously set. Usually this differs from the optimum resolution of a LCD/LED screen. Then this error message will appear.
However, crashing of the computer might happen due to other reasons.
*Defective RAM *Not-so-good VGA *Viruses
You have to make sure the above problems are not the reason for crashes.
Also try playing somewhat older games. If the problem occurs due to your VGA not supporting the new games, older games will work fine.
Try these suggestions and let us know.
Good luck, and thanks for using FixYa!
Oct 30, 2011 | Samsung Digimax 4010 Digital Camera
I have a Samsung Sync master T220p monitor and i have a problem with games that can not support 1920x1200 resolution. I received this Error : Not optimum mode recommended.
u need to fix the resolution 1020x768 pixel and properly install VGA driver.if u have any problem after that plz install a graphic card on your pc
May 27, 2011 | Computers & Internet
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
Resolution message
Right click on your desktop and choose properties. Click on the settings for your problem monitor and you should find the option to change the screen resolution.
Feb 28, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Diplay setting changes made but the color or resolution is still bad.
I have a similar problem with this monitor, i always after connecting having to go to the "screen Position and Size" setting in my ATI FireGL. and shift the screen 1 pixel, and the color and resolution turn ok, it is manual step, but better than no fix
Jan 23, 2008 | ViewSonic Televison & Video
Showing "not operating in optimum mode"
reinstall the display drivers in safe mode this you can do by pressing F8 and in safe mode, you can also try restoring the machine to previous state Good Luck
Jan 19, 2008 | Samsung 710V 17" LCD Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
124 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
