Fellowes DS9Cs shredder will not turn on after unplugging. Green light has gone off - what next?
I removed the top to empty shredder. Replaced it and the green light was off. Unplugging/replugging it in hasn't helped. Any suggestions? Thanks!
SOURCE: My shredder stopped working
This shredder is supposed to reset after 15 minutes.
Posted on Dec 10, 2007
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
  • 105 Answers
SOURCE: I have a Fellows Powershred ps 60cc and removed
the shredder has a safety switch that closes when the unit is put back on the basket. check under the cutter head for the hole that has the switch and check your basket for the acuator put together so they will line up
Posted on Nov 17, 2009
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
Shredder stopped suddenly and won't work
If you are unable to clear the jam, turn off and unplug the shredder;
remove shredder head from the wastebasket and carefully remove any paper extending
below the cutting cylinders; empty the wastebasket; reassemble the shredder and repeat
if still do not run follow the next steps:
1. Make sure shredder is plugged in and
switch is in automatic [I] position.
2.Wait 15 minutes for shredder to cool
down before trying again.
3.make sure that the shredder head is in the correct position, if is not it will not run
please rate the post for i to know do this is helpful if not i will know by your rate that i should post some more information
Jan 11, 2010 | Fellowes P70CM Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
Why does shredder full light stays on after emptying.
There is a photo cell or switch that detects when it is full, this may be covered by a scrap of paper or paper dust. Make sure the shredder is unplugged and use a flashlight to look for the photo cell and use a small thin brush to clean it, If you clean it and it still indicates that it's full the photo cell or switch may have gone bad and will need replacing.
Sep 10, 2009 | Fellowes Office Equipment & Supplies
Basket full light on
without seeing the product, there are 2 (two) things to check.
First, unplug the shredder and go underneath where the bin full flap is. Sometimes paper debris gets stuck between the flap and switch. Check to ensure the switch is not out of adjustment. you'll have to remove the top cover to perform this. Otherwise, your PC Board is defective.
Mar 02, 2009 | Fellowes 2200 Cross-Cut Shredder
Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Short run time and redlight, stops running Fellowes DM15C
There are two sensors (look like little light bulbs) on the top part of the shredder at either end of the blades. If you pull out the drawer and turn the shredder upside down you will see them. They get dirty telling the machine that it is full and needs to be emptied. Clean the sensors off with an alcohol wipe. If cleaning them does not work you need to replace the sensors.
Aug 25, 2008 | Fellowes DM15C Shredder
24 people viewed this question
k24674
jasbo
jasbo
