Question about Maytag Neptune MDE4000 Electric Dryer
Matag neptune dryer MDE40000AYW Manual - Maytag Neptune MDE4000 Electric Dryer
4 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: I have a matag neptune gas dryer and it does not
The heat will not turn on for a few reasons or possibly just one
First remove the exhaust duct work and clean thoroughly
Any lint build up will cause the moister sensor to put the burner in check
Also after you had cleaned it and still no heat, listen for the spark ignitor to click when first turned on. That ignites the burner. If no clicking is heard the spark ignitor is at fault. If it does work the moister sensor is at fault instead
Posted on Jun 25, 2010
Jahn27
  • 1554 Answers
SOURCE: I need a replacement control
You can find all the knobs you need for your machine here.
Maytag MDE4000AYW Knob Parts
Posted on Nov 01, 2010
oldTech2332
  • 2341 Answers
SOURCE: My matag neptune dryer MDE5500AYW
The DO error code means DOOR OPEN and what ya would need to check is the door switch because it seems as if even though the door is closed it thinks its open
also here is the link to the service manual for that dryer.
http://www.appliance411.com/PDFdocs/16023110.pdf
GENE
Posted on Sep 24, 2011
WHY DOES MY NEPTUNE MATAG DRYER MDE5500AYW NOT HEAT ...AND WHERE ARE THE THERMAL SWITCH, HI LIMIT THERMOSTAT, AND HEATING ELEMENT?
All those parts are in the bottom front. TURN off the power! then open the front door and remove the 4 screw's, 2 on the hindges and 2 on the other side. Then you can close the door, and pull from the top edges of the front panel(sometimes you need a thin screw driver to free the front) the front panel will tilt forward and then you can lift it off. You will need a Ohm meter to check those parts for continuity. Make sure you remove the wires from the part you are testing.
Sep 30, 2014 | Maytag Neptune MDE5500AY Electric Dryer
My matag neptune dryer MDE5500AYW has error code of DO, and the dryer doesn't function. Is there a error code list? Is there a part that I can replace? Is there a repair manual I can get?
GENE
Sep 24, 2011 | Maytag Dryers
Matag dryer lde412 not heating elec
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My matag dryer is about 5 yrs old. when I run the dryer it sounds like metal on metal and I can,t get the back off.
Access is thru the front. Remove the door hinges and the screws on opposite side. Use your thumbs to gently twist frame towards you and remove. The top panel is held on with clips and screws that are noticeable. From there you should be able to locate metal dust where the root of the problem is.
Eric
Aug 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a matag neptune gas dryer and it does not heat up but turns I am not sure the year of it . It is digital
Jun 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
Matag Dryer to LP gas
Here is a link to a thorough explanation of what is involved in a conversioin and what to look for.
http://www.propane101.com/lpgasapplianceconversions.htm
May 23, 2009 | Maytag Neptune MDG5500AW Gas Dryer
8.8. on Display
Mine had a fried control board. $150.00 for the part, did the work myself. Will not be putting any more money into these Matag Neptune pieces of junk after this. Will buy another brand of washer and dryer.
Feb 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
