Question about Panasonic PT-L785U Multimedia Projector
Image on screen is upside down
I just installed an pt-L785u on the ceiling,the mounting screws are on the bottom of unit,so the proj..has to be mounted upside my image on screen is upside do i adjust unit to show rightside up..thanks jeff
  • 1,098 Answers
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Posted on Oct 15, 2010
Projector screen upside down
Check the settings for image alignment. You may have to look for the vertical and horizontal image settings.
This could be because the default is table mount and you may have mounted on ceiling.
Aug 26, 2014 | Panasonic VIERA Televison & Video
How do you rotate the picture
If u have installed the projector to the ceiling, u will see the image upside down. for this u need to orient the projector image upside down
use the remote,
go to menu, installation, front ceiling option, u are done!
Dec 07, 2012 | Panasonic PT-AE8000U Full HD 3D Home...
Upside down picture on Vivitek D530
Check the Projection setting on the Installation I menu of the OSD
Feb 11, 2012 | Vivitek D530 Projector
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar.
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Panasonic PT-L785U Multimedia Projector Logo
1,721 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
