Question about Philips DVP642 DVD Player
Toshiba disc error
I have a Toshiba dvd player,model sd-1200y.When I load a disc it reads "disc error".The same disc however plays ok on my Phillips dvd player.What am I doing wrong? thanks
  • Anonymous Mar 14, 2014
    Error code 3 and error code 1 vcr light flashing
  • Anonymous Mar 23, 2014
    Toshiba SD-V280U
    Genius:
  • 1,153 Answers
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Posted on Sep 05, 2007
SOURCE:
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
The player just stop play dvds and cds, it states disc error. powers on fine but it just won't play. takes a while on loading.
seems to be problem of ur opticle assembly which is used to read the disc try to figure out problem with cleaning disc run or just clean the laser by help of dry leather dont us cotton or any cloth
regards if still unsatisfied clear the whole symptom & write to me again let me know ok!
Jul 18, 2010 | Toshiba SD-9200 DVD Player
Won't load DVD
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Apr 21, 2009 | Televison & Video
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Dec 22, 2007 | Toshiba SD-1200 DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Philips DVP642 DVD Player Logo
543 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
