Question about Dryers
Bosch wta 2730 - Dryers
2 Suggested Answers
SOURCE: Bosch Axxis WTA 4400 dryer
if you can hear a whirring then the motor is probably spinning, and the problem may just be a broken belt.
If no sound, then probably power not getting to motor via PCB
Posted on Apr 26, 2008
Dryer doesn't power-on.
Simple answer: way too much dryer lint. Worth cleaning out.
Mar 04, 2018 | Bosch Axxis WTA 3510 Electric Dryer
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch wta 3100 no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Why does my bosch dryer wta 2910 only blow cold air?
If the exhaust vent tubes have never been removed and thoroughly cleaned in years this will cause the sensor to keep the heat off in your dryer. If clean the moister sensor is at fault
May 02, 2010 | Bosch Axxis WTA 3500 Dryer
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Drive Belt on BOSCH WTA 3003 dryer
No,It`s quite a difficult & fiddly job.
Nov 10, 2008 | Bosch Axxis WTA 3003 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
95 people viewed this question
Top Dryers Experts
