I want to reuse the water for my next wash with my WD-8013F front loader
Is this possible if so how do I do it???
  • 68 Answers
BAHAHAHAHA!
Posted on Jan 02, 2013
4 Suggested Answers
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
Model WD-8013F. Why does it continue filling after wash cycle should start?
water level sensor may be faulty, or the air tube that works in conjuction with the sensor may be plugged. check out repairclinic.com or appliancepartspros.com for videos on this issue and fixes.
Jul 17, 2015 | LG Washing Machines
Lg 7.5 WD-8013F had sparks and stopped working
Where do sparks come from. Motor is in back.
Mar 10, 2017 | LG WD-80130F
Hi there, I have an LG WD-8013F font loader washing machine that made a loud pop with a burning smell when I tried to run a wash program. I turned it off, and after a while tried the wash program...
semakan
  • memeriksa
  • menyemak
  • ')" onmouseout="ht(this)">check
    capasitor dalam tenaga
  • dalam kekuatan
  • ')" onmouseout="ht(this)">in power
    memasuki
  • masuk
  • memasuk
  • ')" onmouseout="ht(this)">enter
    that duduk di dalam')" onmouseout="ht(this)">staying inside.
    Nov 20, 2010 | Washing Machines
    Lg intellowasher wd-8013f is very noisy
    it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
    May 09, 2010 | Washing Machines
    hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
    where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
    same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
    the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
    then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
    Dec 01, 2007 | Washing Machines
    DRUM BEARINGS sorry
    Oct 15, 2007 | Washing Machines
    Washing Machines Logo
    18 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
